Received the "Failed to Load Driver for device entry #[2 or 3]" error message
985
    Introduction
    Error Message Appears for Access Points with One Radio
    Resolution
    When you install VxWorks firmware version 12.03T in an access point with one radio, an error message appears. If your access point contains only the internal 2.4-GHz radio, this error message appears:
    ** Failed to Load Driver for device entry #3.
    If your access point contains only the external 5-GHz radio, this error message appears:
    ** Failed to Load Driver for device entry #2.
    You can ignore these messages. The errors do not appear if your access point contains two radios.
    This error message appears for 1200 series Access Points (APs) with one radio. If you have firmware version 11.50T in an AP with one radio, an error message appears.
    Problem Type
    Error message
    Products
    Access point
    AP 1200
    Reference
    Content for Community-Ad
