Sample configuration example of an 871W ISR
21392
Introduction
/image/gif/paws/98499/ISR_Authentication-1.gif
Solution
This configuration example has 2 vlans, vlan 1 and vlan 2 , each mapped to a different SSID with WPA-PSK security
sh run
Building configuration...
Current configuration : 2452 bytes
! Last configuration change at 23:53:27 UTC Wed Mar 27 2002
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$.lNK$ellDG1B2CZJnj82Wqn8iL0
no aaa new-model
dot11 syslog
dot11 ssid GUESTRITS
vlan 2                                       <<<vlan 2 mapped to GUESTRITS SSID...Use the vlan as per the network configuration
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 cisco123
dot11 ssid INTERNAL
vlan 1                                    <<<<<<<vlan 1 mapped to INTERNAL SSID
authentication open
ip source-route
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.254
ip dhcp pool GUESTRITS                       <<<<We have a DHCP pool for GUESTRITS SSID...wireless users connecting to this SSID will get IP from this pool
    network 192.168.1.0 255.255.255.0
    default-router 192.168.1.254
ip cef
cwmp agent
management server username 00000C-CISCO871W%2dG%2dA%2dK9V05-FHK12502AJ2
bridge irb
interface FastEthernet0
switchport trunk allowed vlan 1,2,1002-1005     <<<We are allowing only the vlans meant for wireless access...Modify this as per the needs
switchport mode trunk
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip                 <<<tkip is the cipher
encryption vlan 2 mode ciphers tkip
ssid GUESTRITS
ssid INTERNAL
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native                      <<<vlan 1 is native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan2
no ip address
bridge-group 2
interface BVI1
ip address 10.0.0.2 255.255.255.0
interface BVI2
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee                              <<<Bridge group 1 is always used for bridging native vlan traffic to the radio interface...
        <<< bridge group 2 for bridging vlan 2 with radio interface here...
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
password cisco
login
exception data-corruption buffer truncate
scheduler max-task-time 5000
end
Router#
Reference
Cisco 800 Series Routers Wireless Authentication Types on a Fixed ISR Configuration Example
Wireless, LAN (WLAN) Configuration Examples and TechNotes
Troubleshooting TechNotes
Technology White Paper
WLAN Security Introduction
Wireless, LAN (WLAN) Technology Q&A
Cisco 800 Series Routers Configuration Examples and TechNotes
Rising star
Hi Ritika,
thanks for sharing the sample configuration example. keep it up . 5+
Beginner
This is what I got and it has been working for me, and this includes the wireless setup. From my modem to my RV016 to my 871w.  Once I figure out the PPPOE the 871w will be my only router running, and figure out the port forwarding, but most important I need to configure PPPOE.
mr-r1#sh star
Using 3825 out of 131072 bytes
! Last configuration change at 08:10:30 PCTime Sun Oct 28 2012 by ramosm
! NVRAM config last updated at 08:10:33 PCTime Sun Oct 28 2012 by ramosm
version 12.4
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname mr-r1
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 64000
logging rate-limit 20
enable secret 5 $1$PDK9$YSz8GsnVsDYevR1hVGMG70
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone PCTime -8
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-3978252741
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3978252741
revocation-check none
rsakeypair TP-self-signed-3978252741
crypto pki certificate chain TP-self-signed-3978252741
certificate self-signed 01 nvram:IOS-Self-Sig#B.cer
dot11 syslog
dot11 ssid ramfam
vlan 55
authentication open
mbssid guest-mode
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 10.25.55.1 10.25.55.49
ip dhcp excluded-address 10.25.55.76 10.25.55.254
ip dhcp excluded-address 10.25.50.1 10.25.50.49
ip dhcp excluded-address 10.25.50.76 10.25.50.254
ip dhcp pool Data
   import all
   network 10.25.50.0 255.255.255.0
   dns-server 10.55.55.1 4.2.2.1
   domain-name MR-Lab1
   default-router 10.25.50.1
   lease 25
ip dhcp pool Wireless
   import all
   network 10.25.55.0 255.255.255.0
   default-router 10.25.55.1
   dns-server 10.55.55.1 4.2.2.2
   lease 25
ip cef
ip domain name MR-Lab1.com
ip name-server 10.55.55.1
username ramosm privilege 15 secret 5 $1$J2cq$abQJlRlZgmIlEDPX/jd8A1
archive
log config
  hidekeys
no ip ftp passive
bridge irb
description AirNet 1100
speed 100
spanning-tree portfast
description Extra cat5
description Ubuntu PC
description PS3
speed 100
description Internet Wan Port
ip address 10.55.55.105 255.255.255.0
ip nat outside
ip virtual-reassembly
speed 100
full-duplex
no ip address
encryption vlan 55 key 1 size 128bit 0 AB2081CA12B126DD2F95ABCF32 transmit-key
encryption vlan 55 mode wep mandatory
broadcast-key vlan 55 change 30
ssid ramfam
mbssid
station-role root
interface Dot11Radio0.55
encapsulation dot1Q 55 native
bridge-group 1
interface Vlan1
ip address 10.25.50.1 255.255.255.0
ip nat inside
interface Vlan55
no ip address
bridge-group 1
interface BVI1
ip address 10.25.55.1 255.255.255.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 10.55.55.1
ip http server
ip http authentication local
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source list 2 interface FastEthernet4 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.25.50.0 0.0.0.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 10.25.55.0 0.0.0.255
control-plane
bridge 1 route ip
line con 0
exec-timeout 30 0
password Cisco
logging synchronous
no modem enable
line aux 0
line vty 0 4
exec-timeout 20 0
password Cisco
logging synchronous
end
mr-r1#
Beginner
let me know what I can add or remove.
