The AIR-LMC352 client cards cannot be used with laptops
1321
Resolution
An IEEE 802.11b-compliant 2.4-GHz 11-Mbps Personal Computer Memory Card International Association (PCMCIA) card radio module is usually pre-installed in a device equipped with an internal Type II or Type III PC card slot. Host devices usually include handheld or portable devices.
The LM card is available in the 340 and 350 series. It is not made to be used with laptops since it requires an AIR-ANT3351 antenna that needs to be inserted on the card.
For more information on the client adapter, refer to the Introduction to the Client Adapters section of Chapter 1 - Product Overview.
For more information on related topics, refer to these documents:
Problem Type
No connectivity
Products
WLAN adapters (wireless card) / ACU (Aironet Client Utility)
AIR-LMC352
Client Adapter Errors, Warnings, Statistics and Log Messages
no radio found
Content for Community-Ad
Cisco COVID-19 Survey
