The "Interface Dot11Radio0 Radio over temperature detected" error message appears on the bridge 1410 that runs Cisco IOS Software Release 12.3(8)JEA
1047
Core Issue
This issue is due to Cisco bug ID CSCsg56375. The bridge syslog reports the Interface Dot11Radio0 Radio over temperature detected and the radio interface will intermittently go down spurious message.
Resolution
The problem is first found in these Cisco IOS software releases:
  • Cisco IOS Software Release 12.3(11)JA
  • Cisco IOS Software Release 12.3(8)JA02
  • Cisco IOS Software Release 12.3(8)JEA
It is fixed in these Cisco IOS software releases:
  • Cisco IOS Software Release 12.3(11)JA01
  • Cisco IOS Software Release 12.3(8)JEA01
Basically, the bridge reports the %DOT11-3-RADIO_OVER_TEMPERATURE: Interface Dot11Radio0 Radio over temperature detected error message in the log. The radio interface then intermittently resets / fails. This happens because the ambient temperature is cool, somewhere between 32 degrees Fahrenheit and zero degrees Fahrenheit.
There is a fix implemented on the latest Cisco IOS software releases:
Upgrade to either of these Cisco IOS software releases in order to resolve the problem.
Refer to these documents:
Problem Type
Error message
Products
BR 1400
Bridge
Product OS
IOS
Content for Community-Ad
