The "Object "CalibrationModel#xxxx" does not Exist " error message appears when attempts are made to create a new calibration model with a WCS that runs version 4.0.66.0
1140
Core Issue
An error like this can appear:
"Error:  You must correct the following error before peocedding:
Error: Object "CalibrationModel#5886" does not Exist."
Resolution
In order to workaround this issue, complete these steps:
  1. Try to reinitialize the database with this command:
    C:\Program Files\WCS#\bin>
    DBAdmin.exe reinitdb
  Note:This command would erase the database completely. All the   calibration models would have to be redone.
2. Try again with a blank database, and see if the problem persists.
3.  Uninstall version 4.0.66.0 of the WCS and install version 4.0.96. Then, import the database, and it works.
Refer to these documents for more information:
Problem Type
Error message
Products
Wireless Control System
Content for Community-Ad
