The radio shuts down after you upgrade the firmware
1451
Core Issue
This occurs after upgrading the firmware on the access point or the 350 series bridge.
Resolution
If you are running firmware version 11.21, use the following procedure:
  • Select yes for the Require use of Radio Firmware X.XX setting on the AP/Root Radio Advanced page, and follow the upgrade steps again.
Also refer to the "Require Use of Radio Firmware x.xx section" of the Configuring the Radio and Basic Settings document.
Problem Type
Upgrade
Interference issues ( EMI / RF issues)
Products
AP 340, 350
AP 1200
BR 350
Content for Community-Ad
