The WPA-PSK does not work with local MAC authentication
2294
Core Issue
The Cisco Access Point (AP) does not support local MAC authentication and Wi-Fi Protected Access Pre-share Key (WPA-PSK) in the same Service Set Identifier (SSID). When you enable local MAC authentication with WPA-PSK, WPA-PSK does not work. This happens because local MAC authentication removes thewpa-psk ascii password line from the configuration.
Resolution
For more information and workarounds for this issue, refer to Cisco bug ID CSCef02795.
Problem Type
Error message
Products
Access point
Content for Community-Ad
