Unable to establish a point-to-point connection between the Cisco Aironet 1400 Series Wireless Bridges
821
Core Issue
The root and non-root bridges cannot associate with each other. The status of the non-root bridge radio is RESET, and the protocol is DOWN.
Resolution
This issue is documented in Cisco bug ID CSCsb08590.
As a workaround, perform these steps:
  1. Download Cisco IOS  12.3(7)JA or later from Cisco.com as a "recovery image."
  2. Issue the archive command or use the GUI in order to download the "recovery image" into the BR1410 Flash.
  3. Issue a command similar to the one listed in order to recover the radio:
    bridge#dot11 dot11Radio 0 recovery-fw flash:c1410-k9w7-mx.123-7.JA/6501.img
    Note: Issue the dir Command-Line Interface (CLI) command in order to verify the actual filenames.
  4. Issue the archive command or use the GUI in order to reload the desired code into the bridge.
    Note: There is the option to stay on Cisco IOS 12.3(7)JA rather than fall back to version 12.3(4)JA, or to apply version 12.3(4)JA.
Refer to Mounting and Alignment Overview for more information on bridge mounting and antenna alignment.
Refer to Cisco Aironet 1400 Series Wireless Bridge Ordering Guide for more information on the Cisco Aironet 1400 Series Wireless Bridge.
Refer to Configure the Bridge for the First Time for more information on how to configure the bridges.
Refer to Cisco Aironet 1400 Series Wireless Bridge 28-dBi Dish Antenna for more information.
Problem Type
No connectivity
Products
Bridge
BR 1400
Role in Radio network
Root bridge
Non Root Bridge
Topology
Point to point network
Wireless Stages
Unauthenticated and Unassociated
Content for Community-Ad
Cisco COVID-19 Survey
