Upgrade software for an access point
615
Core Issue
You may need to upgrade software due to the following:
  • Corrupted image
  • Upgrading as a part of regular update process which is not recommended as the current version works fine.
  • Fixing the Bugs and errors in the previous version.
Resolution
The documents that address managing your firmware and configurations describe how to:
  • update the firmware version on an access point.
  • distribute firmware to other access points.
  • distribute the access point's configuration to other access points.
  • download, upload, and reset the access point configuration.
The Managing Firmware and Configurations document for your particular platform can be found:
As an example refer to Release-notes section of Cisco 1100 series access point for downloading softwares. Go through the release-notes document for the corresponding access points. You can get this by navigating to  product document of each access point.
Problem Type
Upgrade
Products
Access point
Content for Community-Ad
