Users unable to perform AP configuration or firmware update jobs when two WLSEs are managed in high availability mode and also not able to log in to the WLSE GUI.
844
Core Issue
When the Java Cryptography Extension (JCE) certificate expires, key CiscoWorks Wireless LAN Solution Engine (WLSE) functions are unavailable until the patch is installed. This includes High Availability (HA), configuration, and Cisco Access Point (AP) firmware update jobs.
Resolution
This problem is tracked in Cisco bug ID CSCsb39389.
These are possible workarounds for this issue:
For WLSE 1130, upgrade to a newer release, such as WLSE 2.11. Download these files from the Cisco Software Center:
File Name: WLSE-2.11u-K9.zip
Readme: WLSE-2.11-K9.readme-V2.txt
For WLSE 1105 running Release 2.7.1 or 2.7, download these files from the Cisco Software Center:
File Name: WLSE-2.x-CSCsb39389
Readme: WLSE-2.x-CSCsb39389.readmeV1.txt
Problem Type
Configure / Configuration issues
No connectivity
Software issues
Products
Access point
Device Access Method
GUI Interface
Content for Community-Ad
