Featured Speaker
George Stefanick is a Wireless Architect employed by a large healthcare system in the Texas Medical Center. His Wi-Fi engineering experience spans nearly two decades and in that time he has provided consulting to many Fortune 500 companies in industries such as healthcare, mining, and hospitality. He maintains a popular Wi-Fi engineering community, the blog MY80211.com and he holds many vendor and vendor neutral certifications..
As a member of the Cisco Support Community, George has been awarded with a Cisco Designated VIP status, a recognition that Cisco bestows upon the most valuable and influential members of their official technical support community.
A: Ultra High Density will go beyond common client support per AP, applications like stadiums will require a better performance for APs to process requests. Optimized roaming and Rx-SOP, together with specific AP models (p series for 3700) 2800/3800 series will also provide double 5GHz radios to provide 2 different cell per AP and distribute clients into 2 different collision domains. All in a single area.
A: There isn't one size fits all, you would want to use RRM when possible but you also need to design accordingly so that it can be leveraged effectively.
A: Yes you can, but it will be dependent on the adapter that you are using for surveying, not all of them report the noise floor.
A: You can find the answer to this question on the Ask the Expert event.
A: AireOS is not going anywhere any time soon, new features are AireOS first.
A: Depends on the application, for example for voice deployments the general guideline is to not exceed 20% of retries.
A: When you’re interested in expanding more you need to have a look that it’s the right opportunity.
At the hospital we expand under the opportunity of a corporative place, in which we can do cost savings. That is, no much infrastructure and less cables.
A: For local SSIDs, our recommendation is to keep a top of 4 SSIDs available per location. External SSIDs are best to negotiate with their owners to follow better ways to reduce the coverage in your location.
A: Depends on your requirements and lifecycle strategy. There are already a few gaps of features that are only supported on newer WLCs.
A: You will sometimes want to start at L1 and the switch where the AP is connected.
A: Depends on where you are located and how prone are specific channels to see radar.
A: I recommend looking at the release notes to understand the open and resolved caveats in specific releases for that platform.
A: Here is a sample on one of their locations 802.11a 12M Rate............................. Mandatory
802.11a 18M Rate............................. Supported
802.11a 24M Rate............................. Mandatory
802.11a 36M Rate..............
A: Yes, currently DFS channels are not used in most of the locations.
A: If possible you would do a predictive survey, a physical pre-deployment survey (passive or active depending on requriements), implement, then follow up with post-deployment survey to gather data to fine tune and have a baseline.
A: That depends on the type of application you want to give to clients, data-only can provide good service for more than 50 clients per Radio. Voice and video will decrease the number to 17 to 25 tops.
With AVC, AP can identify the specific traffic from the softphone app and define specific QoS marking: http://www.cisco.com/c/en/us/products/collateral/wireless/8500-series-wireless-controllers/qa_c67-722538.html
A: Personal preference is to keep it with DHCP.
A: Primarily Omninpeek is used by George for packet captures.
A: It can be many things affecting the signal coming from the AP at the location, if link quality decreases, client will negotiate lower modulation scheme to still understand the frames. a proper RF study is recommended. With AVC, AP can identify the specific traffic from the softphone app and define specific QoS marking: http://www.cisco.com/c/en/us/products/collateral/wireless/8500-series-wireless-controllers/qa_c67-722538.html
A: Typically, but there are reasons why you would want to do an active survey after a deployment.
A: There is a difference on the theoretical value of associations that an AP supports, and what is valid and realistic for a particular environment. I would recommend focusing more on doing a proper capacity design to derive the clients/AP ratio you need.
A: There are several deployment guides that cover this topic quite well and provide good direction on where to start.
A: WLC by default provides Rogue AP detection, it normally reports all heard SSIDs and sources which are not part of the WLC or Rf group. For details about SSIDs classification: http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_0111110.html
A: The deployment is using TPCv1, no UNII3 channels were disabled.
A: Depends of the requirements and devices that you will connect and also how you want to segment them.
A: If possible RF attack has been discarded. But for accurate assistance we recommend to not hesitate on opening a case with Cisco TAC.
A: Being evaluated and tested, specially adaptive 11r.
A: It’s a challenge, but everything is based in relationship in which through communication you provide the understanding of the reasons why certain legacies are needed.
A: WLC can provide you with summary of RF status per AP. 'Monitor- Access Points - Radios - <a-b>. Hover over the blue button of the AP. Click on 'detail'.
You should see channel utilization, noise floor, and interference per channel. CleanAir data will also identify the source of the interference based on the signal pattern.
A: Normally you will see some bleedthrough because of the nature of RF, what you would want is to secure it properly.
A: In certain scenarios it could potentially delay the association/roaming, so for example in voice deployment you tend to not enable it on the ssid used for voice devices.
A: Please find more information in the following link: http://blogs.cisco.com/wireless/dont-sweat-the-small-stuff-its-okay-to-mix-cisco-access-points
A: Methodist is currently using PI for both wireless and wired.
A: If AP is not receiving IP address, make sure L2 and relay agent are properly configured for the AP management VLAN. Lightweight AP satate machine will attempt to get IP address every 5 minutes.
If you still face issues do not hesitate to contact TAC, we will be glad to assist you with your specific issue.
A: For 5760, https redirect could use many hardware resources and TAC should identify the the WLC load to determine no issues with the use of this feature.
A: If you are talking about the WLCAA then yes, is constantly being updated as new requirements and best practices are learned.
A: The main reason is the lack of support of 802.11r from wireless clients, Management 802.11 with FT frames may not be properly processed by those devices and they wont attempt to join the SSID.
A: All roles have their respecitve purpose, depends on your requirements which one you will use. I know plenty of flexconnect deployments where that role is a better fit.
A: Currently DFS channels are not being used on most of Methodist locations.
A: Due to the limitantion of the 2.4GHz band, yes you want to try to use 5GHz as much as possible.
A: we recommend looking at the release notes to understand the open and resolved caveats in specific releases for that platform.
A: We typically design 5Ghz. We try to use AP and create more cells, ones that may reach all devices including a cellphone which are minimum ones.
A: WLC provides rogue AP containment which basically floods an BSSID with disassociation frames, this only remomended as a temporary approach, but the best is to phisically try to physically shut down the offender. Denying service at a non-licensed spectrum may incur in legal problems.
A: Depending the WLC model, we can have more than 500 different SSIDs configured, but keep in mind that each AP will only support up to 16 different SSIDs per Radio.
A: Noramlly you want to leave it dynamic.
A: You really need the right tools to be able to work on the propper design.
A: There is a bulk update option in PI. You can use templates at PI to define a set of configurations to be applied to many APs registered, all at the time: http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-1/user/guide/pi_ug/config-temp.html
A: If you have control on the endpoint you can do some mapping there, else you could leverage features like AVC on the WLC.
A: Yes, for instance we have Cisco Prime and other software packers. But at the end it all comes down to comfort and needs
A: Majority are 3702, this is their current standard.
A: Omnipeek was used for taking the captures for the most part.
A: We use peek appliance. So you want to go to sniffing tools for detail analysis. When you configure Cisco Aps you have the ability to configure different types of moods,one of them is sniffer.
You reboot the sniffer AP and put the IP address and you set a channel, this will send all the information to the appliance.
A: George has used and considered AireWave for other projects, but for Methodist implementation PI is the one that better meets the requirements for both wired and wireless.
A: Or if you want to apply RF profiles.
A: It is very challenging, that is when internal discussion has to happen on the teams to determine what is needed and feasible. It is problematic, because eon BYO environments you don’t necessarily own those assets. Usually in a corporate environment is a major effort.
A: It all comes down to what are the applications used on the AP. This will determine the solution, for instance not all applications needs high band. On the 3700, we have done it on 5 and 8.
A: Depends a lot on the application, this link is for HD but should give you an ideo on how to look at things, have a look to: http://www.cisco.com/c/dam/en_us/solutions/industries/docs/education/cisco_wlan_design_guide.pdf
A: They have different radios and antenna options, you should evaluate what are your requirements and make your selection acordingly.
A: We have a spread sheet that we go through, we look at how well this device is working here. You test variations on the drives, then you modify, once you modify you review how is behaving since the last check. Those are some of the things we look for, in fact they’re very basic things.
It’s very important that you Vaseline, compare that that provides you data to compare and then improve.
A: Depends a lot on the application, this link is for HD but should give you an ideo on how to look at things http://www.cisco.com/c/dam/en_us/solutions/industries/docs/education/cisco_wlan_design_guide.pdf
A: When you’re in BYO environment you don’t necessary have control in those devices so it’s recommended to delimitate some standards in that state the recommended drives for them, but it’s not possible to provide recommendation to all of them.
A: Without AVC (application and Visiility Control), all traffic from the laptop will be marked with the QoS value configured at the SSID (silver, gold, platinum).
A: For BYO we don’t necessarily have a policy to bring your own device, instead we provide a guest network in which users can connect with their own device. At least in hospital that is how we do it.
A: It is totally up to the client/driver logic and varies per device.
A: It comes down to the design requirements, for instance small offices will do with simple pressure keys whereas more robust corporate environment EP with locking. Also, since BYO is a trend a lot of corporates are looking at MDM so they have full control of all those assets.
A: There is a lot of discussion going around this. We do subscribe our RRM and we do have some static areas. When doing RRM you need to have a design to support it, it needs to be understood and modify according to the needs.
A: Yes certainly, it’s a comfort level. A typical build out would be wireless and wired.
A: Everything is wireless with the exception of the conference room, where we have 4-5 phones and printers. There are no cable to any of the tubes nor to any of the offices.
A: AP tx for 3800 series will provide up to 23dBm, please consider the total EIRP to meet regulatory restrictions. BYOD is a challenge, as George mentions, he has focused the effort to standarize at least production devices. La environments with every devices expected at the network is a good approach.
A: When we did the AWO one of the things we did was testing the 5Ghz to make sure all the devices could connect, once we make it happen we changed. In fact when we moved into 5GHz, we never took away the 2.4 band, so device son that standard could connect.
It was a very calculated process in which we never let devices to have no connection, till we were sure they could.
A: The first 2-4months I wanted to hide, we had many things to work out, but we didn’t give up. Management support was critical when we deployed AWO at the hospital.
