Core Issue
Resolution
CiscoWorks Wireless LAN Solution Engine (WLSE) provides Management Frame Protection (MFP). Management frames between Access Points (APs) are authenticated, eliminating several WLAN attacks that occur due to spoofing of authorized devices. CiscoWorks WLSE enables MFP in the network and provides visibility into network events associated with MFP detection or protection.
For more information on WLSE, refer to these documents:
Problem Type
Definitions
Release notes / product overview / data sheet / FAQ.
Products
SW Features
