What is the maximum number of VLANs supported on an Access Point or bridge?
3134
Resolution
A VLAN is a switched network that is logically segmented by functions, project teams, or applications, rather than on a physical or geographical basis.
For example, all workstations and servers used by a particular workgroup team can be connected to the same VLAN, regardless of their physical connections to the network or the fact that they might be intermingled with other teams. VLANs are used to reconfigure the network through software, rather than physically unplugging and moving devices or wires. There can be a maximum of 16 VLANs supported on an Access Point (AP).
For more information on the maximum number of VLANs supported on the AP, refer to the Incorporating Wireless Devices into VLANs section of Configuring VLANs.
Note: You cannot configure multiple VLANs on repeater APs. Repeater APs support only the native VLAN.
Problem Type
Definitions
SW Features
VLANs
Content for Community-Ad
