Which are the Lightweight APs and wireless LAN controllers that support REAP and H-REAP
1009
Resolution
The Remote Edge Access Point (REAP) mode enables a Lightweight Access Point (LAP) to reside across a WAN link and still be able to communicate with the Wireless LAN Controller (WLC). REAP also provides the functionality of a regular LAP. The REAP mode is only supported on the 1030 LAPs at this point. This functionality is included on a broader range of LAPs in the future.
Note: The 1030 AP supports REAP, but the 1010 and 1020 AP does not support REAP.
Hybrid REAP is supported only on the 1130AG and 1240AG access points and on the 2000 and 4400 series controllers, the Catalyst 3750G Integrated Wireless LAN Controller Switch, the Cisco WiSM, and the Controller Network Module for Integrated Services Routers.
Refer to these documents for more information:
Problem Type
Technical product specification / features
Definitions
Release notes / product  overview / data sheet / FAQ
Products
Wireless LAN Controllers
Lightweight Access Points
Content for Community-Ad
Cisco COVID-19 Survey
