04-27-2012 12:33 AM - edited 11-18-2020 02:58 AM
FlexConnect is a wireless solution for branch office and remote office deployments. Prior to WLC Release 7.2, FlexConnect was referred as Hybrid REAP (HREAP). Now it is called FlexConnect.
FlexConnect feature enables customers to configure and control Access Points through a wide area network (WAN) link without deploying a controller in each branch office. The FlexConnect access points can switch client data traffic and perform client authentication locally when their connection to the controller is lost. When they are connected to the controller, they can also send traffic back to the controller. In the connected mode, the FlexConnect access point can also perform local authentication.
FlexConnect is supported on the Cisco Aironet 1130AG, 1140, 1240, 1250, 1260, AP801, AP802, AP3550, and Cisco Aironet 600 Series OfficeExtend Access Points on the Cisco WiSM, Cisco 5500, 4400, 2100, 2500, and Flex 7500 Series Controllers, the Catalyst 3750G Integrated Wireless LAN Controller Switch; the Controller Network Module for Integrated Services Routers.
FlexConnect (previously known as Hybrid Remote Edge Access Point or H-REAP) is a wireless solution for branch office and remote office deployments. It enables customers to configure and control access points in a branch or remote office from the corporate office through a wide area network (WAN) link without deploying a controller in each office. The FlexConnect access points can switch client data traffic locally and perform client authentication locally when their connection to the controller is lost. When they are connected to the controller, they can also send traffic back to the controller. In the connected mode, the FlexConnect access point can also perform local authentication.
Figure shows a typical FlexConnect deployment.
text box.
ID text box
Choose MONITOR > Clients or MONITOR > Summary to verify whether the clients are getting associated to the Flexconnect AP.
Cisco Wireless LAN Controller Configuration Guide - Configuring FlexConnect
Cisco WLC Configuration Guide, Release 7.5 - Configuring FlexConnect
We plan to locate one or two wlc 3504 (most likely two in ha/sso) in the main dc. Access points are located at several remote sites at the same time. It is assumed to use the following scheme,
10.x. y. z/24, where x is the site code, y is the wifi management vlan number, z is the device address.
Let's say 50 is the main dc code, 51 is the first site code, 52 is the second site code, and so on. The wifi management vlan has one number on all positions - 20. It turns out the following scheme, 10.50.20.2-wlc 3504 in the main dc, 10.51.20.2-20-access points on the first site, 10.52.20.2-20-access points on the second site, and so on.
In this particular case, we want to set the port on the switch to which the wlc is connected as "access".
is it possible use same vlan number for same wifi network from different sites. for example, if we use vlan 10 for wifi_work in every site, can we use for every site? Or we need use 10 vlan for fisrt site, 11 for second, 12 for third etc.
In our particular case, dhcp pools for wifi_management and wifi users created locally (router-on-a-stick or l3 switch). Screen from previous message is from one of current wlc, which we plan to change by new one (this 2504 located in main dc, but all access points - in remote site).
If i understood you correctly, we can not to create this interface with vlan number, if we want define traffic locally. If we want to define wifi traffic centralized - we need to do it.
And this scheme should be work scheme?
site 1 - vlan 10 wifi_work - 10.1.10.0/24
vlan 20 wifi_guest - 10.1.20.0/24
site 2 - vlan 10 wifi_work - 10.2.10.0/24
vlan 20 wifi_guest - 10.2.20.0/24
site 3 - vlan 10 wifi_work - 10.3.10.0/24
vlan 20 wifi_guest - 10.3.20.0/24
In the wlc in main dc
