Type | Description | State |
Bug | CSCto37213 AP group parsing "10011,Error parsing AP Groups, AP name not found" if AP name is > 20 characters | Fixed 2.3.2 |
Bug | CSCto13320 AP group parsing in 7.2 reporting "10011,Error parsing AP Groups, AP name not found" | Fixed 2.3.1 |
Bug | CSCto17815 AP with default username, is not generating message | Fixed 2.3.1 |
Feature | CSCto37589 WLCCA: report offending line for parsing errors | Pending |
Feature | CSCto30825 Warn if wlan mappings are not the same across wlcs with hreap | |
Bug | When using the “Copy Contents to Clipboard” feature within the main config set window, the contents of the “Voice Messages” tab cannot be copied. Instead, the contents of the “Global Messages” tab are sent to the clipboard. | Pending |
Bug | Clicking on RF summary APs in the tree, does not move the grid | Fixed 2.14 |
Bug | RF index should take into consideration 40 MHz channels | Pending |
Feature | Autoinmune warning for voice, using 6.0.188 config | Pending |
Feature | Count rogue containment rules,and warn if they are more thant X number, as it can cause performance impact | Pending |
Feature | Button to reset settings to default | Pending |
Feature | Informational message if no radius accounting is configured | Pending |
Feature | Warn if A-MPDU for priority 0 is disabled | Pending |
Feature | Warn if multicast forwarding is enabled, and address is 0.0.0.0 | Pending |
Feature | Check if hreap local switching is enabled, "do not learn IP" is checked on wlan, and webauth is in use | Pending |
Feature | Warning if mobility timers do not match across mobility peers | Pending |
Feature | Warining if WLC is referenced as anchor, but does not have itself as anchor in wlan | Pending |
Feature | Graph: Client distribution per AP radio | Pending |
Feature | Improve compensated power in 11a TPC view, so it takes into consideration max level depending on bands enabled and country used | Pending |
Feature | Parse and show properly 6.0.188.0 Coverage hole detection data | Fixed |
Bug | AP group parsing in 4.2 | Fixed |
Feature | Warn if Expedited BW Request Status is enabled for 5.2. and bellow | Fixed |
