WLC Config Analyzer HowToAP
4628
AP Tree
It will show all detected access points from the loaded "sh run-config" files. The initial view is ordered alphabetically in a tree, with all the APs from all the controllers.
Opening an access point node will show the radios it has installed. Clicking on it, you can see all summary data for the radio, including RRM profiles, and current settings.
Content for Community-Ad
July's Community Spotlight Awards
