frodestra
we're running WLC9800 with version 16.12.2s and would like to implement 2,4 and 5 GHz only SSIDs separetely but there seems to be no options for this with the new WLC9800.
The closest place I could find is under WLAN configuration  - Radio Policy, see attached photo
Any suggestions?
Rafael E
Radio policy is used to only broadcast and SSID either on 5GHz (select 802.11a) or 2.4GHz (select 802.11g or 802.11bg)
frodestra
Ok, so for example 802.11 will also include 802.11n when used on the 5GHz band?
Scott Fella
Yes that is correct. Basically like Rafael mentioned, either 2.4 only, 5 only or both.
