Hi, we have ap3802 and wlc 2504. After the ap joined the wlc, the default password(Cisco) cannot work. Can I get it back or do something else? Thank you
Hiwe have three offices all running with their own 5508's. I plan on replacing those WLC's with newer ones. Is there a design were I can replace they with a pair in our CoLo data center and have all the AP's talk back to them? I used to do this with HREAP...
view more
Hi,We have 5520 wlc and we are using RTU license.Currently we are using 100 license and trying to add some more licenses , while trying add more license getting an error like "licenses cannot added/removed on secondary HA /SKU cont...
view more
Hello,I have a AIR-AP1852I-E-K9 set up as a Primary Controller and I'm having trouble connecting the other AP which is an AIr-AP1832I-E-K9 to the network. I can't see the other AP in Rogue APs or anywhere else.Both of them have Mobility Express insta...
view more
Hello i have acces point 1130AG and i want to configure " Security: Global SSID Manager" but i can't save cpnfigure from interface web ap .. so i can allow AP accept paramter " Security: Global SSID Manager" that i can se...
view more
