I use 1852i ME as a WLC, and via 2960 POE connect other 1852i and 1702i aps.
They can't support iphone roaming, but it can support the iPad and tablet and Android.
Refer the picture, I enable these functions.
6 Comments
Leo Laohoo
1. Fastlane: Turn it off 2. iPhone having problem? What firmware is it running on?
Thanks very much.
The iPhone have no problem. When one iPhone connect one AP, then it can connect wifi, but if this iPhone move to another location and near to another AP, and it can't connect another AP. Only turn off iPhone's wlan and open it again, then it can connect wifi.
Cisco wlc is 8.8.100 (newest version image). All iPhones have the same issues.
Thank you again. I try it to turn Fastlane off.
Leo Laohoo
8.8.111.0 was released last week. I recommend you try this out.
Try disabling Fast Transit over the DS (WLANs -> SSID -> Security -> Layer 2). This will probably fix this issue. Had the same issue at a customer site, disabling it fixed this.
With kind regards,
Marcel Tempelman.
Thank you, Marcel.
My version is 8.8.100. There is no Fast transit, and there is Fastlane under traffic shaping. Fastlane is equal to Fast transit?
"5GHz EDCA Fastlane Description—Configuring the EDCA Profile as Fastlane improves Apple device performance on 5GHz networks."
Thank you.
Hay friend
i had this issue before
u have to do 4 things
1st enable advanced mode in the top
2nd disable fast lane
3rd in ssid go to advanced and disable 802.11k , 802.11r , 802.11v
4th enable client band select and client load balancing
hope this helps as it did with me
Thank you.
French webcast-routing
