09-10-2014 03:28 AM - edited 11-18-2020 03:08 AM
8.0MR2 is now in beta; see https://supportforums.cisco.com/document/12492986/80mr2-beta-availability .
Final build posted to CCO. 8.0.110.0, beta is closed
Thanks for your interest!
For any new issue during this test, please write to wnbu-mrbeta@external.cisco.com, pre-existing problems would be directed through normal TAC support channels, the image is TAC supported until CCO release of final code
AS_5500* can be used for Wism2/2500/5500 controller types
AS_7500* can be used for 7500/8500
AS_CTVM can be used for vWLC
CSCur88408 LAP doesnt send discovery request to WLC IP discovered by DNS resolution
CSCur56103 Jian Active Silent crash
CSCuq27304 Apple IOS7 devices not able to pass traffic in 11v+FTDot1x wlan
CSCur44620 Radio reset after Flex+Bridge AP recovers from standaloneCSCur12358 1532 AP channel announce on DFS not working
CSCur27399 ap702w lan port wired client traffic gets disturbed.
CSCur16761 outdoorAPs going to Local mode with "clear capwap privateconfig" command
CSCuq81885 DHCP fails Flexconnect Local Switching MAC Filtering RADIUS VLAN assign
CSCuq41792 XALE: Iphone6/Samsung 11ac clients deauthe'd on 11r roam reassoc request
CSCup66509 BGL-Alpha: #OSAPI-0-INVALID_TIMER_HANDLE: [SA] timerlib_mempool (TRCBK)
CSCuq94967 WLC: iPhone 6 displays as an Nortel-Phone for Device-Type
CSCuq97267 Anchor clients not able to see custom webauth page; SSL to WLC GUI fails
CSCur00985 Local Policy created from GUI gives an error if the day is Sunday
CSCur46621 OEAP600:radCfg config get lost after upgrade due to CSCuq04522
CSCuq89707 IOS AP OpenSSL August 2014 vulnerabilities
CSCuq33165 Loss of jumbo state config on upgrade from 7.6 to 8.0
CSCur23139 vWLC: Client cannot access network after reconnect
CSCuq49638 Pre-auth flex-ACL can not be applied on AP when AP joined the WLC
CSCur21198 Coverage hole detection not working as expected.
CSCur21984 Memory Usage Increasing on Bonjour Services While Running 8.0.100.0
CSCur15784 Flex-Bridge fails to maintain MAP & client connectivity.
CSCur09386 FlexConnect Vlan mode changed to Disabled after power cycle (1242/1131)
CSCuq04522 OEAP access points lose config after power cycle
CSCug34802 rogue detector AP fails to corelate and contain wired rogues on 5ghz (1130/1240)
CSCub75472 Rogue AP detection on wire fails if radio mac is 1 of ethernet mac (1130/1240)
CSCuq79572 8.0.100.1- 5500 crashing continuously -ipv6socetTask
CSCuq89956 AP in local mode, 1550, crashes on show mesh forwarding port-state
CSCup84060 Radio interface down with rcore on 1130 and 1240 APs
CSCuq42751 WLC not sending all the Client attributes to PI
CSCuq34493 Unable to queue 802.11a AP PLM message
CSCup55898 IPv6 DTLS negotiation failure in Local and FlexConnect modes
CSCuq96360 702W : LED not working for the lan ports in autonomous mode
CSCuq40682 Optimized Roaming does not work
CSCuq82202 WLC hung - No free Mbufs (ARP Fllod) available
CSCup94796 QoS bandwidth contracts not cleared with fast-ssid-switching
CSCuq90997 PMIPV6 crash WLC 7.6 Reaper Reset: "PMIPV6_Thread" taking too much cpu
CSCuq92650 WLC memory leak on 7.6 post PIMPV6 implementation
CSCur13703 Central Webauth with HTTPS redirect fails
CSCup59877 %DOT11-2-NO_CHAN_AVAIL_CTRL: Interface Dot11Radio2, no channel available
CSCup47579 AP Core Dump check box disabled (GUI), AP mode change from Flex to Local
CSCuq73119 Need knob to suprress all RADIUS Interim Acct Updates per WLAN
CSCuq61876 %DOT11-2-NO_CHAN_AVAIL_CTRL: Interface Dot11Radio2, no channel available
CSCup96353 HA enabled Controller crash, Task: NFV9_Task
CSCuq86750 NDP packets on 3700 abnormally low TX power
CSCuq61451 wrong cert while accessing wlc by ipv6 address and https
CSCuq61753 Lobby admin broken on 8.0.100.0 on WLC 2500
CSCuq50181 OpenSSL issues, August 2014 - WLC
CSCuq57637 15.3(3)JA AP IOS crash loop with "Release image validation failure"
CSCup46986 The 1st dhcp client needs to be kicked off after detected duplicate IP
CSCup92277 Controller responds to SYN-FIN scans
CSCuq14453 Memory leak on WLC when using PMIPv6 clients
CSCuq18402 Slave AP not connecting over daisy chain
CSCuq55372 8.0 - WLC crash with Flex AP and Local Switching Enabled
CSCup43052 WLC crashes after starting client roaming
Hi Javier,
the link above didn't work for me, I had to manually change to https for reaching the files.
https://upload.cisco.com/cgi-bin/swc/fileexg/main.cgi?CONTYPES=wng-escalation
Stefan
Hi Stefan,
Thanks. It is now corrected.
Regards.Salil
when will 8.0 MR1 be published as a final code ?
hi Kristjan
we plan to publish 8.0MR1 this month.
it is on finalizing stages now
regards
