victor1977
Community Member
Dear All
we got a AIR-CT2504-K9 and a AIR-CAP1602I-E-K9.  after initial config.  controller web page.I can not find the ap in wireless page.
but in neighbours , I can find it.  and it has got the ip address from out DHCP server.
I check a lot of document, the AIR-CT2504-K9 with Product Version.................................. 7.0.220.0 can not attach AIR-CAP1602I-E-K9 ,right?
The following is the config of AIR-CT2504-K9
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... system
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.6.187
Last Reset....................................... Software reset
System Up Time................................... 0 days 0 hrs 7 mins 10 secs
System Timezone Location......................... (GMT +8:00) HongKong, Bejing,
Chongquing
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
--More-- or (q)uit
Next Boot License Type........................... Permanent
Configured Country............................... CN  - China
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +30 C
External Temperature............................. +34 C
Fan Status....................................... 4200 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 6C:20:56:B9:22:00
Maximum number of APs supported.................. 5
The following is the message from AP
Translating "CISCO-CAPWAP-CONTROLLER.QD.HPC.GRP"...domain server (192.168.6.151)
*Mar  1 00:23:56.353: %CAPWAP-3-ERRORLOG:
*Mar  1 00:23:59.353: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROL
LER.QD.HPC.GRP
*Mar  1 00:23:59.353: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'system'r
unning version 7.0.220.0 is rejected.
*Mar  1 00:23:59.353: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:23:59.353: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m
essage type 2 state 2.
*Mar  1 00:23:59.353: %CAPWAP-3-ERRORLOG: Failed to handle capwap control messag
e from controller
*Mar  1 00:23:59.357: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap p
acket from 192.168.6.187
*Mar  1 00:23:59.357: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'system'r
*Mar  1 00:23:59.357: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:23:59.357: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process m
yusuf habibi
Beginner
Beginner
you should upgrade soft.version WLC, AP 1600 series first support 7.4.100.60
Recognize Your Peers
