Serge Yasmine
Here is a very basic configuration example on an 871 ISR Router with an open ssid on a flat vlan 1 for wired and wireless users served from local dhcp server on ISR.
Serge
Router#sh run
Building configuration...
Current configuration : 2018 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool LAN
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.254 255.255.255.0
controller DSL 0
line-term cpe
bridge irb
interface FastEthernet0
description WAN
ip address 10.10.10.2 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface Dot11Radio0
no ip address
ssid test
    authentication open
    guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0
no ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEthernet0 overload
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line aux 0
line vty 0 4
login
no scheduler allocate
end
Router#
ramosm1974
Beginner
Beginner
This is what I got and it has been working for me. From my modem to my RV016 to my 871w.  Once I figure out the PPPOE the 871w will be my only router running, and figure out the port forwarding, but most important I need to configure PPPOE.
mr-r1#sh star
Using 3825 out of 131072 bytes
! Last configuration change at 08:10:30 PCTime Sun Oct 28 2012 by ramosm
! NVRAM config last updated at 08:10:33 PCTime Sun Oct 28 2012 by ramosm
version 12.4
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname mr-r1
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 64000
logging rate-limit 20
enable secret 5 $1$PDK9$YSz8GsnVsDYevR1hVGMG70
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone PCTime -8
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-3978252741
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3978252741
revocation-check none
rsakeypair TP-self-signed-3978252741
crypto pki certificate chain TP-self-signed-3978252741
certificate self-signed 01 nvram:IOS-Self-Sig#B.cer
dot11 syslog
dot11 ssid ramfam
vlan 55
authentication open
mbssid guest-mode
ip source-route
ip dhcp excluded-address 10.25.55.1 10.25.55.49
ip dhcp excluded-address 10.25.55.76 10.25.55.254
ip dhcp excluded-address 10.25.50.1 10.25.50.49
ip dhcp excluded-address 10.25.50.76 10.25.50.254
ip dhcp pool Data
   import all
   network 10.25.50.0 255.255.255.0
   dns-server 10.55.55.1 4.2.2.1
   domain-name MR-Lab1
   default-router 10.25.50.1
   lease 25
ip dhcp pool Wireless
   import all
   network 10.25.55.0 255.255.255.0
   default-router 10.25.55.1
   dns-server 10.55.55.1 4.2.2.2
   lease 25
ip cef
ip domain name MR-Lab1.com
ip name-server 10.55.55.1
username ramosm privilege 15 secret 5 $1$J2cq$abQJlRlZgmIlEDPX/jd8A1
archive
log config
  hidekeys
no ip ftp passive
bridge irb
description AirNet 1100
speed 100
spanning-tree portfast
description Extra cat5
description Ubuntu PC
description PS3
speed 100
description Internet Wan Port
ip address 10.55.55.105 255.255.255.0
ip nat outside
speed 100
full-duplex
no ip address
encryption vlan 55 key 1 size 128bit 0 AB2081CA12B126DD2F95ABCF32 transmit-key
encryption vlan 55 mode wep mandatory
broadcast-key vlan 55 change 30
ssid ramfam
mbssid
station-role root
interface Dot11Radio0.55
encapsulation dot1Q 55 native
bridge-group 1
interface Vlan1
ip address 10.25.50.1 255.255.255.0
ip nat inside
interface Vlan55
no ip address
bridge-group 1
interface BVI1
ip address 10.25.55.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.55.55.1
ip http server
ip http authentication local
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source list 2 interface FastEthernet4 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.25.50.0 0.0.0.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 10.25.55.0 0.0.0.255
control-plane
bridge 1 route ip
line con 0
exec-timeout 30 0
password Cisco
logging synchronous
no modem enable
line aux 0
line vty 0 4
exec-timeout 20 0
password Cisco
logging synchronous
scheduler max-task-time 5000
end
mr-r1#
sevier.toby
Community Member
Great post, very helpful!
