06-27-2013 02:11 PM - edited 11-18-2020 03:03 AM
Upgrade note: If you have an HA setup, it's important to note that HA must be REMOVED (not just disabled) prior to starting an upgrade. Administration > High Availability > HA Configuration > Remove button.
Note regarding PI_1_3_0_20-Update.1.12.tar.gz: this patch is NOT required to apply PI_1_3_0_20-Update.4.16.tar.gz, however, if you have already applied this patch, Update.4.16 can be applied directly over any other PI_1_3_0_20-Update.1.xxxx.tar.gz patches.
PI_1_3_0_20-Update.4.16.tar.gz is a cumulative patch, consisting of Update 1 and internal updates 2 & 3, as well as the Chrome patch (CSCui77571).
Current Version | Upgrade Path | Required Files - in install order | Notes |
NCS 1.1.0.58 | 1.1.0.58 => 1.3.0.20 Update 4 | ncs_patch-1.1.0.58-upgrade-12.tar.gz | Patch required to upgrade to PI 1.3.0.20. Backup and Restore required before proceeding. |
PI-upgrade-bundle-1.3.0.20.tar.gz | Upgrade bundle taking current patched version to PI 1.3.0.20 | ||
PI_1_3_0_20-Update.1.12.tar.gz | Patch taking to PI 1.3.0.20 Update 1 - Not required, but if you have already applied this patch, here is where you are in patch sequence. | ||
PI_1_3_0_20-Update.4.16.tar.gz | Patch taking to PI 1.3.0.20 Update 4 (this patch can be installed on top of all other "PI_1_3_0_20-Update.1" patches, but those others are not required) | ||
NCS 1.1.1.24 | 1.1.1.24 => 1.3.0.20 Update 4 | ncs_1_1_1_24-Update.13.4.tar.gz | Patch required to upgrade to PI 1.3.0.20. Backup and Restore required before proceeding. |
NCS 1.1.2.12 (FIPS) - See Service Advisory below | 1.1.2.12 => 1.3.0.20 Update 4 |
| Must take a backup of existing 1.1.2.12 and restore into a patched version of 1.3.0.20 (new server) |
NCS-patch-1.3.0.20-CSCue74129.tar.gz | Patch required on top of 1.3.0.20. Once patch is installed, you can restore the backup from 1.1.2.12 | ||
NCS 1.1.3.2 (FIPS) - See Service Advisory below | 1.1.3.2 => 1.3.0.20 Update 4 |
| Must take a backup of existing 1.1.3.2 and restore into a patched version of 1.3.0.20 (new server) |
NCS-patch-1.3.0.20-CSCue74129.tar.gz | Patch required on top of 1.3.0.20. Once patch is installed, you can restore the backup from 1.1.3.2 | ||
PI 1.2.0.103 | 1.2.0.103 => 1.2.1.12 => 1.3.0.20 Update 4 | pi_1.2.1.12_update.tar.gz | Installed on 1.2.0.103, upgrades to 1.2.1.12 |
PI_1_2_1_12u-Update.1.tar.gz | installed on upgraded server now running 1.2.1.12. This fixes bug CSCue50717. | ||
PI 1.2.1.12 | 1.2.1.12 => 1.3.0.20 Update 4 | PI_1_2_1_12-Update.1.0.tar.gz | Patch required to upgrade to PI 1.3.0.20 |
PI 1.3.0.20 | 1.3.0.20 => 1.3.0.20 Update 4 | PI_1_3_0_20-Update.1.12.tar.gz | Patch taking to PI 1.3.0.20 Update 1 - Not required, but if you have already applied this patch, here is where you are in patch sequence. |
Documentation Links:
Offical documenation covering Upgrading Prime Infrastructure: http://www.cisco.com/en/US/docs/wireless/prime_infrastructure/1.3/quickstart/guide/cpi_qsg130.html#wp56675
Service advisory for NCS 1.1.2.12 and NCS 1.1.3.2: http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/1.3/software/advisory/Software_Advisory_CPI_1_1_2_and_1_1_3.pdf
Installing the point patch: http://www.cisco.com/en/US/docs/wireless/prime_infrastructure/1.3/quickstart/guide/cpi_qsg130.html#wp69624
Performing Inline Upgrade: http://www.cisco.com/en/US/docs/wireless/prime_infrastructure/1.3/quickstart/guide/cpi_qsg130.html#wp65395
Software Links:
NCS 1.1.0.58 - PI 1.2.1.12 patches: http://tools.cisco.com/squish/53bFA
PI 1.3.0.20 Upgrade Bundle: http://tools.cisco.com/squish/F171c
PI 1.3.0.20 Update 1 & Update 4 patches: http://tools.cisco.com/squish/ab3d5
Reviewing the "Tips for upgrading to Prime Infrastructure " support forums document is also extremely helpful.
