The WLC Config Analyzer home has moved to Cisco DEVNET. See:
https://developer.cisco.com/docs/wireless-troubleshooting-tools/#wireless-config-analyzer
We also have a cloud version of the tool: https://cway.cisco.com/tools/WirelessAnalyzer/
_______________
Historical info
(please use new forum for updates)
Wireless LAN Controller (WLC) Config Analyzer
Download
Click here to Download
To request access, send an e-mail to wlc-conf-app-dev@cisco.com. Please include your Cisco.com username. Cisco employees do not need to request.
- New version 4.0 Nov 2015
- You may need to install .NET 3.5 before using it.External link to download:
http://www.microsoft.com/en-us/download/details.aspx?id=17718
News
March 31 2015. Version 3.6.5
Enhancements
- Tool tips added on AP grid
- AP MIC expiration warning
- Flex Policies information on WLAN table
Fixes
- Minor parsing errors
- Wrong text message on 100003
- Wrong error on missing information on WLANS for custom web profiles
February 04, 2015. Version 3.6.4
Fixes
Typos on messages
RF health exception if neighbor AP had no power level
Incorrect calculation of side channel interference could lead to zero health
Incorrect parsing of mobility peers when new mobility is enabled
No text for message 2005
WLAN data rates nor parsed properly, display error
Message tab columns had incorrect order
NGWC:
Parsing error on coverage information line
Parsing error on peer to peer wlan state
Corrected WLAN table display
Parsing of AP groups
January 15, 2015. Version 3.6.3
Fixes
- 11b RF group peers not properly tracked
- Corrected text for messages 40043, 30062 for clarity
- Fixed false detection of telnet enabled on WLC
- Added detection for parsing error on DCA Monitor channel line
- Fixed password length check (120013)
December 17, 2014. Version 3.6.1
Enhancements
- IOS-XE improved support: best practices, mobility parsing, GUI display. Partial support for RF summary, 3.7 RF information
- Serial number in AP summary table
- Filter per band in AP RF summary table
- On Channel Neighbors count in AP RF summary
Fixes
- Power distribution graph level 1 not displayed
- Exception while parsing 5760
- RF Health calculation for Side channel noise in 5 Band
- RF problem finder window scale issues on VMWare
- High SNR client stats missing
November 20, 2014. Version 3.5.3
Fixes
October 10, 2014. Version 3.5.2
Fixes
- Detecting Empty mesh BGN in AP config
- Incorrect reporting of standalone TKIP in use, when there is no dot1x or PSK policies set
- Corrected warning for empty IP Address on redundancy interfaces
- Message wmm required for 11ac/11n not displayed when parsing a single wlc
- Exception on 7.3 configs without RF profiles
- Improved error reporting on parsing lines
- Incorrect parsing of flex AP mode
- Partial fix for window size problem on rf problem finder tool. Disable Aero interface in Windows if still having problems.
- Handles gracefully AP list corruptions (adds AP creation in AP group information)
- Properly parses Channel 14 Interference/Noise data as NA, in ETSI APs
- Fix on Nearby list processing, if last line in AP is corrupted
- Fix on parsing of system info\Management IP address
- Fixed logic of message 30062 (false positive)
- Fixed duplication of message 30057 for some scenarios
- Fixed parsing of Static WEP state
- Null error on best practices checks for some configs
- Fixed parsing error on incorrect line separator
- Fixed error on percentage display on best practices summary
Enhancements
- 43 new checks
- Best Practices score analysis
- Flexgroup and FlexAP support
- Displays DHCP proxy per interface, compares across controllers
- Parsing, comparison between WLCs, and display of global user idle timeout
- Parsing, comparison between WLCs, and display of WiFi direct, wlan sleep timer/sleeping client feature
- Config Comparison across controllers of DCA mode, selection interval, metric contributors, channel list, and channel width across controllers
- Config Comparison across controllers of TPC mode, power threshold
- Mesh security mode parsing, comparison across controllers
- Displays DCA metric contributions
- New Security Checks category
- WLAN parsing of 11r, SKC, PMF, comparison across controllers
- Parsing, comparison between WLCs, and display of critical management password policies
- WLAN table rewrote for simplification on information displayed, less columns, adds support for 11r, PMF
- Show values to the RXSOP and CA info messages
- AP power state and flex group name to AP config table
- New AP group CSV export
- 8.0 Support. Added RF profile DCA bandwidth, Fixed Parsing error on QinQ AP group info
July 19, 2014. Version 3.4.2
Enhancements
- New Best Practices analysis tool. Focused on checking if "good to use" features are in place
- WPS section parsing
- SSH/Telnet/Fast SSID parsing and display
- Checks for telnet enabled, DHCP proxy mismatch, NTP sync, Management over Wireless added
- Improved readability of WLC/Site summary pages
- Added QoS, Local profiling, dot1x info to wlan table
- New Report Center, to launch all supported report files. Disabled default report creation
Fixes
- Significant speed improvements for Neighbor calculation on large networks
- Radius server line parsing error if line was incomplete
- RF Index calculation exception on some files
June 27, 2014. Version 3.3.1
Enhancements
- Added message summary per WLC/Site
- HTML report ad CSV file generation is now disabled by default
- New Report Center being added (work in progress)
Fixes
- Correct library installation for Chart component on some PCs
- Moved to .Net 3.5 client profile for lower memory/startup time
- Exception error on RF Health calculation when unknown nearby data was found
- Fixed RF Health metric for side channel noise/interference
June 27, 2014. Version 3.3.0
Enhancements
- Added warning if TKIP standalone is used
- WLAN table enhancements: displays encryption types, AVC
- AP graph can be filtered by AP group
- Improved message 60011 with compensated power data
- New RF Health metric for ease of detection of problematic areas
Fixes
- Corrects parsing of 4.2 WLC files
- Reduces problem on .Net library load (lower time when opening config set for first time)
- Fixes problem on AP manager check with vlan untagged scenario
- Fixes problem on redundancy parameter parsing
- Fixes logic of message 30065
April 23, 2014. Version 3.2.4
Enhancements
- Added partial support for 5760/3850 NGWC controllers. You need to collect "sh tech and sh tech wireless" on same file for each controller (one file per ngwlc)
- Added parsing and display of wlan count per radio on AP config
- Updated warning for controllers with deferred or affected by security advisory versions
- Parses, checks and displays Local EAP status per WLAN
- Parses, checks and displays Rogue Policies, compares settings between controllers
- Parses, checks and displays Clean Air config, compares settings between controllers
- Chart for Client SNR distribution
- Best practices 2.0 Checks
- Recommend to disable 1,2,5.5,11 data rates
- Warn if more than 4 SSIDs active per radio
- Recommend multicast multicast mode for all cases
- Warn if mobility group (same name) > 15 controllers, shows message to reflect that it should cover only the RF roaming space
- Recommend low radius timeout depending on usage scenario (not a general change)
- Warn if EAP identity if <10 sec, and when is needed
- Warn if using internal DHCP server due to scalability issues
- Warn if using local EAP, due to scalability on very large networks
- Recommend to change EAP retries to 4, timeout to 400ms
- Warn if tacacs timeout is short, recommend long times for OTP
- Recommend to have minimum rogue RSSI to -80
- Recommend to disable all rogue auto contain settings, unless absolutely needed for security reasons
- Recommend AVC enabled
- Warn if Fast SSID is not enabled for Apple Clients
- Warn if cleanair is not enabled
Fixes
- Parsing of Tacacs server entries with management timeout values
- Parsing of User Idle timeout per wlan when it is disabled
- Wrong detection of AP on high co-channel
- Corrected redistribution of MS Chart Control (now properly included, and prerequisite)
March 21, 2014. Version 3.1.1
Fixes
- Application error when clicking AP name. Slot0 was not parsed
- Multicast address message only displayed if multicast is enabled (30034)
- RSSI client count calculation error for RF Summary
March 20, 2014. Version 3.1.0
Features
- Adds support for 7.4 to 7.6 versions
- RLAN support
- Displays Redundancy info for 7.6
- Almost full parsing of WLAN configuration
- Displays AP username in AP list
- Parses and displays 802.11n, 802.11ac network status
- Changes how text information is displayed, for ease of reading
- Added Radius Auth Call Station ID support
New Checks
- Warns if 11ac or 11n radios are present, but WMM is disabled on the WLAN
- Warns if 11ac or 11n radios are present, but 11n or 11ac support is disabled on the controller
- Compares Radius Auth Call station ID across controllers
- 78 parameters compared for matching WLANs across WLCs.
- Warns if using HA, and no vlan tagging on management interface
Fixes
- Error while parsing mobility peers
- Corrected that RSSI/SNR client percentage on RF summary per controller, are calculated for 1 controller, and not for all loaded
- Corrected High RSSI client count per controller
- Fixed wrong info on Radius aggressive failover status
- Parsing of Radius servers on new versions
- Parsing error on Mobility peers
Training
RF Health Metric
New in Version 3.3.0
New experimental troubleshooting tool: “RF Health”
This is a modification of the RF index to change the format to a 0 to 100 metric, the higher the better, for a easier to use experience
it should work properly to isolate what areas/Aps of the deployment are having a bad RF state, affecting clients.
RF Health will try to calculate different metrics applicable to RF quality on the AP, and convert to a single 100 based scale. It takes into consideration things like low SNR client count, co-channel interference, channel utilization for nearby Aps, noise, etc.
It currently supports 20/40 channel width, and handles properly bonding scenarios.
You can open “RF problem finder” to get details on the metric per type, per AP, for in depth analysis
Please provide your feedback on the metric, for additional improvements, change on default values, etc.
Support
General Usage: wlc-conf-app@external.cisco.com (you can subscribe)
Bug reports/issues/features: wlc-conf-app-dev@cisco.com
FAQ
WLC Config Analyzer FAQ
How to Use
History
