Tsevya1
Hello Team,
We have several APs with multiple SSID  (autonomous setup, no WLC). A video on demand  (VoD) server is connected into the same switch and operating on the same Vlan.
  • Video quality from media server is crystal clear when a laptop is connected to the switch (hard wire).
  • When users are attempting to view a movie broadcasted  from VoD server, we observed the following:
  • Connection is intermittent, the movie keeps timing out.
  • Buffer errors
  • VoD images are distorted  with poor video quality
However,  wireless users can view  youtube video without any distortion or buffer issue
VoD server broadcasts unicast,   therefore ,  users can pose the movie and view it later without impacting other users.
AP  model and software version: C1600 Software (AP1G2-K9W7-M), Version 15.2(4)JA1, RELEASE SOFTWARE (fc2)
Your assistance is greatly appreciated with this matter.
1 Comment
Tsevya1
MCD-NO105-AP09#show controllers dot11Radio 0
interface Dot11Radio0
Radio Griffin 2.4, Base Address, BBlock version 0.00, Software version 4.10.1
Unused dynamic SQRAM memory: 0x00000E44 (3 KB)
Unused dynamic SDRAM memory: 0x00000000 (0 KB)
Number of supported simultaneous BSSID on Dot11Radio0: 16
Carrier Set: Americas (US) (-A)
Uniform Spreading Required: No
Configured Frequency: 2412 MHz Channel 1
Allowed Frequencies:
2412( 1) 2417( 2) 2422( 3) 2427( 4) 2432( 5) 2437( 6) 2442( 7) 2447( 8) 2452( 9) 2457( 10)
2462( 11)
Listen Frequencies:
2462( 11) 2467( 12) 2472( 13) 2484( 14)
Beacon Flags: 0, Interface Flags 20105, Interface Events 0, Mode 9; Beacons are enabled; Probes are enabled
Configured TxPower: 22 dBm
Allowed Power Levels: 22 19 16 13 10 7 dBm
Allowed Client Power Levels: 22 19 16 13 10 7 dBm
Antenna: Rx[a b c ]
Tx[a b c cck all ofdm all]
Internal
Gain [Allowed 8, Reported 0, Configured 0, In Use 8] (dBi x 2)
Active Rates: basic-1.0 basic-2.0 basic-5.5 basic-11.0
Current Rates: basic-1.0 basic-2.0 basic-5.5 basic-11.0
Allowed Rates: 1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
All Rates: 1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2
Default Rates: basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2
Best Range Rates: basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2
Best Throughput Rates: basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2
Current Voice Rates: basic-5.5 basic-11.0 6.0 12.0 24.0 [disabled until voice packet-discard enabled]
Default Voice Rates: basic-5.5 basic-11.0 6.0 12.0 24.0
Managment Rates: basic-1.0
Multicast Rates: basic-1.0 basic-2.0 basic-5.5 basic-11.0
Multicast Active rate: 5.5
RTS Rates: basic-1.0 basic-2.0 basic-5.5 basic-11.0
RTS Active rate 1.0
RTS Max rate 11.0
Local Packet Rate Probing is disabled : Packet Size 1
Data Rate Sensitivity (rate, SNR dB, Contention dBm)
( 1.0, 10, -93) ( 2.0, 10, -92) ( 5.5, 11, -90) (11.0, 14, -90)
( 6.0, 15, -89) ( 9.0, 16, -88) (12.0, 18, -88) (18.0, 19, -86)
(24.0, 20, -85) (36.0, 24, -81) (48.0, 27, -78) (54.0, 31, -77)
ERP settings: protection mechanisms.
Neighbors in non-erp mode:
Hardware Beamforming: Configured Yes, Active Yes
Number of MFP Indices: 10
RFID Tag Detection: Disabled
Multicast Address filtered:
Packet type filtered:
00 0C rm_scn
Probe limit: active off, filter on, count 0, time 0
Assoc limit: active off, count 0, time 0
GAS Req limit: active off, count 0, time 0
Radio Management (RM) Configuration: Regular AP, Mode 1, Disabled
MCST RSCs: [0]0x0 [1]0x0 [2]0x0 [3]0x0 [4]0x0 [5]0x0 [6]0x0 [7]0x0 [8]0x0
TKIP **bleep** Stats: STA MIC-L-Errs MIC-R-Errs Replay C-Measure
0000.0000.0000 00000000 00000000 00004193 00000000
AES-CCMP **bleep** Stats: 00000000 replays discarded
Channel Utilization Extensions: Disabled
SMPS Mode: Enabled
QBSS Load: 0xE4, Policing Stats: Rx downgrades 0, Tx downgrades 0
Classifier Stats tx_on_up6 0, tx_on_up4 0
Configured Local Access Class Parameters
Back : cw-min 4 cw-max 10 fixed-slot 7 admission-control Off txop 0
Best : cw-min 4 cw-max 6 fixed-slot 3 admission-control Off txop 0
Video : cw-min 3 cw-max 4 fixed-slot 1 admission-control Off txop 3008
Voice : cw-min 2 cw-max 3 fixed-slot 1 admission-control Off txop 1504
Configured Local Custom Access Class Parameters
Best : cw-min 1 cw-max 2 fixed-slot 1 admission-control Off txop 0
Configured Cell Access Class Parameters
Best : cw-min 4 cw-max 10 fixed-slot 3 admission-control Off txop 0
Video : cw-min 3 cw-max 4 fixed-slot 2 admission-control Off txop 3008
Voice : cw-min 2 cw-max 3 fixed-slot 2 admission-control Off txop 1504
SIP stats sip_udp_rx_pkt 0, sip_tcp_rx_pkt 0,downlink classified_pkt 0,uplink classified_pkt 0,num_processed_SIP_Calls 0
Off Channel Rdy 0 Done 0 0 0
Transmit queues: Limit 4245 Current 0 In-Progress 0 AMSDU In-Progress 0 APSD In-Progress 0
---- Active --- In-Progress --------------- Counts --------------
Cnt Quo Bas Max Cnt Quo Bas Sent Discard Fail Retry Multi
Uplink 0 64 0 0 0 5 0 0 0 0 0 0
Voice 0 128 0 0 0 60 0 309010 0 16827 37538 17920
Video 0 1024 0 0 0 90 0 0 0 0 0 0
Best 0 1024 0 0 0 90 0 251337048 709651 12590 138536145267484
MC0 0 0 0 0 0 12 0 49065 2304 1 0 0
MC1 0 0 0 0 0 12 0 10172973 91876 472 0 0
MC2 0 0 0 0 0 12 0 668567 13613 0 0 0
MC3 0 0 0 0 0 12 0 16226 761 0 0 0
Back 0 128 0 0 0 10 0 0 0 0 0 0
BSSIDS Index Flags State Next Held Defer NonDefer Clients Tsf Dtim Txq
3080 0 00 0 0 0 0 0 0 0 2 0e
3081 1 00 3 0 0 0 0 1 148 2 1e
3082 2 00 0 0 0 0 0 0 24 2 2e
3083 3 00 0 0 0 0 0 65535 172 2 3e
Driver TX blocks: in use 0, high 0, at reset 0, fail 0 drop 0
Off Channel Stats: Last Duration 0, Errors: Timeouts 0 Tx 0 Intr 0
---Clients 0 AID VLAN Status:S/I/B/A Age TxQ-R(A) Mode Enc Key Rate Mask Tx Rx BVI Split-ACL Client-ACL L2-ACL
(Client) MaxPri DefUniPri DefMultPri WiredProt
RxPkts KBytes Dup Dec Mic TxPkts KBytes Retry RSSI SNR
IP Address Pauses Idle RateTx RateDataTx RSC
MVL RI=00000000, Req=0, In=0
Video Report: Cnt Rate Retries/Tot
8021x auth in prog 0 allowed 0
Vlan BSSID Clients PSP Pri/U/M HT Encr Key0 Key1 Key2 Key3 iGTK SSIDs MFP
0n 3080 0 0 0 0 0 0 0 0 DIS
1 3080 0 0 0 0 0 0 0 0 DIS0
8 3081 1 0 0 0 0 0 0 34 DIS CORP 0
90 3082 2 0 0 0 0 0 0 0 DIS CrewConnect Hotspot 0
14 3083 3 0 0 0 0 0 0 0 DIS CrewFlix 0
7 3080 0 0 0 0 0 0 0 34 x128 DIS CLIENT 0
Packet Tx (in radio) Metrics
Max Stuck time: Normal 33 MC 12 Off Channel 0
Stuck Cnt Normal MC Off Channel
Paks > 30 Secs 27 0 0
Paks > 20 Secs 61 0 0
Paks > 15 Secs 46
Paks > 10 Secs 22 18 0
Paks > 5 Secs 0
Paks > 1 Secs 0 0 0
0 0 flags 3 match 27
1 1 flags 3 match 21
2 2 flags 3 match 23
3 3 flags 3 match 23
Protocol 12D5
Radio MAC SoC ID: 54, Rev: 1
Data Offsets: 46 72, 0 - 2012, 2 - 2723482, 4 - 1180, 6 - 2091, 8 - 1578, 10 - 22020, 12 - 1066, 14 - 2169, 16 - 1570, 18 - 2176, 20 - 1127, 22 - 2164, 24 - 2029, 26 - 2096, 28 - 1182, 30 - 2180, 32 - 1532, 34 - 2157, 36 - 1077, 38 - 2228, 40 - 1395, 42 - 2169, 44 - 768, 46 - 2148, 48 - 1268, 50 - 2181, 52 - 1167, 54 - 2256, 56 - 1527, 58 - 2237, 60 - 989, 62 - 2340, 64 - 1688, 66 - 2971714, 68 - 1110, 70 - 2313, 72 - 1606, 74 - 24184, 76 - 1102, 78 - 2393, 80 - 1816, 82 - 2287, 84 - 1227, 86 - 2326, 88 - 1799, 90 - 2219, 92 - 999, 94 - 2196, 96 - 1610, 98 - 2249, 100 - 1364, 102 - 2286, 104 - 1466, 106 - 2331, 108 - 1136, 110 - 2195, 112 - 1430, 114 - 2173, 116 - 951, 118 - 2223, 120 - 1868, 122 - 2102, 124 - 1331, 126 - 2155
27A79994 00000005 0000006C 00000000
00000000 00040000 101B0000 00000000 FFFFFFFF
00000000 003F8000 00000000 FFFFFFFF 1307398269 4790
Tx rdy 07A79D78 (07A79C58 - 07A7A4F0)
07A79C58: 7555F82 7731FBE 743DA5E 769BE94 77201EE 76D80FE 7616596 7418A10
07A79C78: 743A58C 7579AC8 75A9EFC 73F63E6 7431156 73DDC9C 76EA960 777370C
07A79C98: 7692A36 6015928 6076D38 600E410 6012038 74CC742 7709A82 73E4664
07A79CB8: 7756582 73E4664 746C97C 774E6AC 74F8C02 773F360 75C461C 740E0D0
07A79CD8: 600DB88 77D4A08 741DE82 74F4200 73BF604 77A10CA 600FDA8 761C500
07A79CF8: 600DA50 74752C2 75F2A82 74AB642 7575082 7607D02 74F2202 75E3702
07A79D18: 768D5C2 75CDA02 75B9202 7693502 74BDE82 771F766 77CCB02 7552018
07A79D38: 76165CC 7534402 7463542 743E4C2 76D9642 758E282 7404202 747B202
07A79D58: 7727682 7699EC2 73FAE0C 740F5C2 75A9EFC 756F188 7527B06 75A9EEE
07A79D78: 0 73BF5D6 75F2A82 7688122 75D2402 76ED382 7585926 755F372
07A79D98: 7460AEA 77E676E 74CC71A 75E220E 741FE5E 73C201A 76C58E6 74D902A
07A79DB8: 73FF7FE 7643502 75E174E 780C282 7462ACE 75A9EC2 746FE42 73BABD2
07A79DD8: 75C45FA 764D3BE 74B6A0E 75343F6 77F1B6E 770CF4A 774B19E 75ABE7A
07A79DF8: 755C92E 78038DA 73CA992 747727A 77B23CA 756287E 74AF5A2 757E492
07A79E18: 770C4CA 753B85E 73E6602 7414A86 7540D06 76DD5B6 77CCAF2 754CB5E
07A79E38: 777CAEA 7573B8A 75ABE86 74A8146 778F34A 76F1306 7791302 7630CCA
07A79E58: 77E678E 740029E 7783F42 7471DDA 7458BFE 76BE46E 73D5302 741DE76
07A79E78: 75956CA 7781FA2 7660676 766CF66 7456C32 75D832E 76F3D46 76BC4DE
07A79E98: 75E0236 73D87C6 73FE2CA 77DBE42 75A0AB6 761AF9A 77912DA 7448E0E
07A79EB8: 74D901A 7808D8E 742B20E 744243A 758F7C2 751FC22 75CE482 7404202
07A79ED8: 780CD1E 7573B82 77D49CE 77A9A56 75152AA 775EEE2 73AE2C2 75574A2
07A79EF8: 73AE2DA 7548BF2 74A178E 77721A6 77DA902 75A1FD6 77369AA 74365CE
07A79F18: 7429D02 75E0CDA 76EA960 75363D0 76E9EA6 766857C 74B89F8 740B656
07A79F38: 765C702 777D57A 74F2CC6 77D4A08 75ABEB8 7674E76 77A9A4E 77893FA
07A79F58: 7458162 780632A 772F54A 7806326 77E47DE 76BDA06 75C4606 76DD5B6
07A79F78: 740F5DA 756B206 77F1B42 751D1BA 74F61AA 753638A 780CD0E 747728E
07A79F98: 73FF7EA 73E65FA 7498E2A 7456C2E 73E6602 7416A16 742923E 75D2426
07A79FB8: 76EE8C2 755747A 73AE2BA 766D9E6 7462ABA 777A0A6 742F19A 77B633E
07A79FD8: 764E8DA 7630CD2 74787E4 77C6BE4 775D9EA 748CF9E 761EF0E 777AB26
07A79FF8: 77BCCF2 769FDF6 74A8184 76BE4A4 747A772 7429D06 75C901E 777F542
07A7A018: 755C932 761658E 755C91A 75667D2 74F618A 73FB86A 75E2C8E 73FB88A
07A7A038: 7554A42 7785482 768D5B6 77E1D72 758E2A6 7562862 769E8A6 77DDDEA
07A7A058: 768F586 74B0052 761703E 7483102 73B8192 7795D02 7462A92 75E177A
07A7A078: 75D43E6 775BA26 7657242 7753B32 7730014 75CAFE4 771044A 7494E8A
07A7A098: 75A7F02 755748A 7424878 76C5900 74787D6 7738986 76321F2 73FAE0C
07A7A0B8: 769FE0C 7789EAE 7416A4A 77D34BE 75A7F36 760528A 741A99E 76FF14C
07A7A0D8: 77E1D98 73FB8A0 73FAE0C 76FF14C 77A9A74 764E8B2 774F140 75F156C
07A7A0F8: 747E718 7710454 7778BAC 76DD5AE 74AB668 758A33C 77E1D5A 766CF88
07A7A118: 7413570 740B680 7496E7C 771041A 7463564 7678DF0 7803914 76EDE44
07A7A138: 7731F8A 76EDE44 76D9658 7585930 77869D0 75E3748 77D34E0 75E3748
07A7A158: 7585930 77C0CB0 7436614 77B9854 77E1D98 743858E 77B982E 75E3748
07A7A178: 7509480 74C3DCC 75B9248 76ABC74 75E2CB4 76008B8 7466A48 73CE950
07A7A198: 7503FE0 778B3DC 77B23F8 740B680 773153C 7680CE0 7693FA4 74D7090
07A7A1B8: 73AE2FC 77932CC 7737470 7730014 7741DB0 76F52A0 75B9CDC 758E2B4
07A7A1D8: 74A2250 74E2464 77EA71C 75A1FE2 77912CA 778B3A6 73B8C2E 74A8184
07A7A1F8: 75554E6 75BA770 74E2464 764351C 7416A54 750C92E 7435B80 7645496
07A7A218: 7650882 742FC2A 77658DA 7710436 7757ABA 74C7D44 7483124 75E0CF8
07A7A238: 7789EB4 77F1B5E 77947C2 77F1B5A 759D5D6 767835C 750C964 77C6BE4
07A7A258: 73C89F2 7676E34 74498D8 73CC994 7797216 7737470 774E6AC 74A4CA0
07A7A278: 75BA732 749ADB6 7460B14 73FAE0C 7460B0A 7414A82 77C0CB0 75D78CE
07A7A298: 7548C00 744247C 770C4AE 774D152 765C714 7435B80 746FE22 7435B80
07A7A2B8: 76EE89A 7463556 766EF16 7676E2A 780B7E2 75DCD76 73FF818 76BF9AE
07A7A2D8: 73CE916 780B804 73C0B2C 74B74B6 7603308 74CC72E 76EE8C6 74CC750
07A7A2F8: 75E2CB4 778F354 77AD9EC 77DDE20 74772AA 768D5DC 77B23DE 757E496
07A7A318: 77A9A3E 746DE9A 76BDA10 77E47AA 77932AA 759D5EA 77E676A 73AE2CA
07A7A338: 7557472 73CFE72 73C0B2C 73CFE46 776AD88 758E2B4 7494EC0 758A33C
07A7A358: 7439AF8 77432CA 75152E8 7527B18 7521122 75E1776 7789420 744AE00
07A7A378: 73CC994 76B9A98 73BABF8 7607CD2 77701E2 745EB58 744E2E4 74F2244
07A7A398: 77E7238 73D1E34 77E7238 777A0D4 73DFC58 7416A54 73DFC58 748DA46
07A7A3B8: 73FB8A0 75DADC4 74498D8 75819B8 7540D10 73CA9D8 751FC28 75819B8
07A7A3D8: 76B45CE 778F354 73E6620 76ED3B0 76F2850 7607280 7503FE0 76C5900
07A7A3F8: 74A17BC 7494EC0 774B1C8 74B749E 75417A4 76EA960 73C0086 76EA93A
07A7A418: 751FC28 7513DB2 748DA4E 73B17A6 753B82A 75F156C 74F8C0C 742F18E
07A7A438: 7471E12 778B3DC 765A72E 75DCD42 75DCD76 76E9EAA 73CC94E 752461E
07A7A458: 77932AA 7588372 7569CE8 73D5318 774BC46 77E7238 7670F00 77E3D42
07A7A478: 73B8C26 75687B6 776AD88 776E22E 75E176E 747A7A0 75730F2 74F2CC2
07A7A498: 761AFC6 74EED1A 73CFE52 7492470 743DA70 780B7DE 77F5042 73B96AE
07A7A4B8: 74C52CE 77701FA 778B3DC 75152E8 7471E1C 761DA28 768F598 77AF982
07A7A4D8: 777CB24 77DF348 7644A44 7569CE8 7760448 74B0074
Off Channel rdy 07A7AD88 (07A7AD88 - 07A7AE28)
07A7AD88: 0 0 0 0 0 0 0 0
07A7AE08: 0 0
Off Channel done 07A7AE28 (07A7AE28 - 07A7AEC8)
07A7AE28: 0 0 0 0 0 0 0 0
07A7AEA8: 0 0
Tx done 07A7A4F0, current 07A7A610
07A7A4F0: 0
French webcast-routing
