03-27-2019 04:38 AM - edited 07-05-2021 10:08 AM
I have 9 access points of different models connected to my 2504 wlc. Currently, the CAP3502I and three LAP1141N have successfully joined the mobility group. Whereas there are three LAP1131AG and one AP1131AG are not listed in the gui.
I have recently converted these AP from LWAPP firmware to autonomous firmware.
Troubleshooting from the ap perspective, they seem to get valid IP addresses from my dhcp router.
Please let me know if you need any outputs. Thanks!
Solved! Go to Solution.
03-27-2019 05:09 AM
If you run the AP's on autonomous IOS (k9w7) images, then they won't be able to join the WLC, they need to be on k9w8 which is the lightweight AP image.
<<< Please help the community by marking useful posts helpful, or accept as a solution if it resolved your issue >>>
03-27-2019 04:43 AM
03-27-2019 04:47 AM
(Cisco Controller) >show sysinfo Manufacturer's Name.............................. Cisco Systems Inc. Product Name..................................... Cisco Controller Product Version.................................. 7.2.111.3 Bootloader Version............................... 1.0.16 Field Recovery Image Version..................... 1.0.0 Firmware Version................................. PIC 15.0 Build Type....................................... DATA + WPS System Name...................................... WLC System Location.................................. System Contact................................... System ObjectID.................................. 1.3.6.1.4.1.9.1.1279 IP Address....................................... 10.10.1.3 Last Reset....................................... Power on reset System Up Time................................... 0 days 2 hrs 51 mins 46 secs System Timezone Location......................... (GMT +9:30) Darwin Configured Country............................... AU - Australia Operating Environment............................ Commercial (0 to 40 C) --More-- or (q)uit Internal Temp Alarm Limits....................... 0 to 65 C Internal Temperature............................. +30 C External Temperature............................. +34 C Fan Status....................................... 3432 rpm State of 802.11b Network......................... Enabled State of 802.11a Network......................... Enabled Number of WLANs.................................. 1 Number of Active Clients......................... 0 Burned-in MAC Address............................ D0:C2:82:E0:8F:80 Maximum number of APs supported.................. 10
03-27-2019 04:48 AM
(Cisco Controller) >show time Time............................................. Wed Mar 27 22:17:03 2019 Timezone delta................................... 0:0 Timezone location................................ (GMT +9:30) Darwin NTP Servers NTP Polling Interval......................... 3600 Index NTP Key Index NTP Server NTP Msg Auth Status ------- ---------------------------------------------------------------
03-27-2019 04:49 AM
AP0017.95b0.c82c# sh ver Cisco IOS Software, C1130 Software (C1130-K9W7-M), Version 12.4(25d)JA1, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2011 by Cisco Systems, Inc. Compiled Thu 11-Aug-11 02:44 by prod_rel_team ROM: Bootstrap program is C1130 boot loader BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(7)JA1, RELEASE SOFTWARE (fc1) AP0017.95b0.c82c uptime is 2 hours, 50 minutes System returned to ROM by power-on System image file is "flash:/c1130-k9w7-mx.124-25d.JA1/c1130-k9w7-mx.124-25d.JA1" cisco AIR-AP1131AG-N-K9 (PowerPCElvis) processor (revision A0) with 25590K/7168K bytes of memory. Processor board ID FHK1018C0CD PowerPCElvis CPU at 262Mhz, revision number 0x0950 Last reset from power-on 1 FastEthernet interface 2 802.11 Radio(s) 32K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address: 00:17:95:B0:C8:2C Part Number : 73-8962-09 PCA Assembly Number : 800-24818-08 PCA Revision Number : A0 PCB Serial Number : FOC10170ZMR Top Assembly Part Number : 800-25544-06 Top Assembly Serial Number : FHK1018C0CD Top Revision Number : A0 Product/Model Number : AIR-AP1131AG-N-K9 Configuration register is 0xF
03-27-2019 05:20 AM
Convert these AP in capwap mode.
You are still using Autonomus image.(
03-27-2019 04:49 AM
AP0017.95b0.c82c#sh ip int bri Interface IP-Address OK? Method Status Protocol BVI1 10.10.1.13 YES DHCP up up Dot11Radio0 unassigned YES NVRAM administratively down down Dot11Radio1 unassigned YES NVRAM administratively down down FastEthernet0 unassigned YES NVRAM up up
03-27-2019 05:09 AM
03-27-2019 06:03 AM
sounds good for a try, i will try it tomorrow and will mark as solution . . Thanks
03-27-2019 10:28 PM
03-28-2019 05:22 AM
the time of my controller is correct, so is the AP. It is the first thing I configure on controller as it does not retain upon reboot.
I have not set up ntp for my network so i would use manual config for now.
