94
Highlighted
Beginner
1562 ME gi0/0/1 tx/rx errors/discards
Hello -
We have a 1562 ME 8.5 with gi0/0/1(DS) showing BILLIONS of tx/rx errors/discards in SolarWInds.
The Master AP is directly connected to a Fortigate FW on a untrusted port natted to a trusted IP address.
Wired0 has no packet drops & the device is serving clients properly.
The following is the "show stats switch detailed" output:
RECEIVE
Octets........................................... 4243466331
Total Pkts....................................... 65808475
Unicast Pkts..................................... 0
Multicast Pkts................................... 0
Broadcast Pkts................................... 0
Pkts Discarded................................... 3694783185
TRANSMIT
Octets........................................... 0
Total Pkts....................................... 402653184
Unicast Pkts..................................... 217065563
Multicast Pkts................................... 3489660928
Broadcast Pkts................................... 217065563
Pkts Discarded................................... 898161759
ADDRESS ENTRIES
Most Ever Used................................... 1
Currently In Use................................. 1
VLAN ENTRIES
--More-- or (q)uit
Maximum.......................................... 128
Static In Use.................................... 1
Time Since Ctrs Last Cleared..................... 53 day 23 hr 33 min 45 sec
Any & all cause or solution ideas are greatly appreciated.
Thank you in advance,
Dave H.
4 REPLIES 4
VIP Advisor
Re: 1562 ME gi0/0/1 tx/rx errors/discards
 Try to clear the stats and see if this value is increasing. This numbers can represent some event in the past and therefore has not relevance anymore.
-If I helped you somehow, please, rate it as useful.-
Beginner
Flavio -
Thanks for the reply.
Still having huge discards.
See below for results:
(AFC_ME_1562_N.CAMB) >clear stats switch ?
Are you sure you want to clear the switch stats? (y/n) y
Switch Stats Cleared.
(AFC_ME_1562_N.CAMB) >show stats switch ?
detailed Display detailed switch statistics.
summary Display switch summary statistics.
(AFC_ME_1562_N.CAMB) >show stats switch de
RECEIVE
Total Pkts....................................... 1780284928
Unicast Pkts..................................... 3618409385
Multicast Pkts................................... 2622195713
Broadcast Pkts................................... 2224815872
Pkts Discarded................................... 3316327268
TRANSMIT
Octets........................................... 2474327434
Total Pkts....................................... 573656505
Unicast Pkts..................................... 2415919104
Multicast Pkts................................... 3282450570
Broadcast Pkts................................... 2691392997
Pkts Discarded................................... 794835338
ADDRESS ENTRIES
VLAN ENTRIES
--More-- or (q)uit
Time Since Ctrs Last Cleared..................... 0 day 0 hr 0 min 21 sec
(AFC_ME_1562_N.CAMB) >show stats switch detailed
RECEIVE
Octets........................................... 539271002
Total Pkts....................................... 167837184
Multicast Pkts................................... 2620622849
Broadcast Pkts................................... 613940992
Pkts Discarded................................... 3323667556
TRANSMIT
Total Pkts....................................... 2483027969
Unicast Pkts..................................... 217065564
Multicast Pkts................................... 1811939328
Broadcast Pkts................................... 3975161947
Pkts Discarded................................... 469313371
ADDRESS ENTRIES
VLAN ENTRIES
--More-- or (q)uit
Time Since Ctrs Last Cleared..................... 0 day 0 hr 0 min 11 sec
VIP Advisor
Run " show int " and let´s see some information like those highlighted below:
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
2 packets input, 128 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
1 lost carrier, 0 no carrier, 0 pause output
Beginner
Flavio -
"show int" command not available in 5.8 ME command set.
AP is connected directly to a FW port with no similar command available like there would be on a cisco switchport.
Thank you,
Content for Community-Ad
August's Community Spotlight Awards
