10-30-2019 05:58 AM - edited 07-05-2021 11:13 AM
Hello -
We have a 1562 ME 8.5 with gi0/0/1(DS) showing BILLIONS of tx/rx errors/discards in SolarWInds.
The Master AP is directly connected to a Fortigate FW on a untrusted port natted to a trusted IP address.
Wired0 has no packet drops & the device is serving clients properly.
The following is the "show stats switch detailed" output:
RECEIVE
Octets........................................... 4243466331
Total Pkts....................................... 65808475
Unicast Pkts..................................... 0
Multicast Pkts................................... 0
Broadcast Pkts................................... 0
Pkts Discarded................................... 3694783185
TRANSMIT
Octets........................................... 0
Total Pkts....................................... 402653184
Unicast Pkts..................................... 217065563
Multicast Pkts................................... 3489660928
Broadcast Pkts................................... 217065563
Pkts Discarded................................... 898161759
ADDRESS ENTRIES
Most Ever Used................................... 1
Currently In Use................................. 1
VLAN ENTRIES
--More-- or (q)uit
Maximum.......................................... 128
Static In Use.................................... 1
Time Since Ctrs Last Cleared..................... 53 day 23 hr 33 min 45 sec
Any & all cause or solution ideas are greatly appreciated.
Thank you in advance,
Dave H.
11-04-2019 09:44 AM
Try to clear the stats and see if this value is increasing. This numbers can represent some event in the past and therefore has not relevance anymore.
-If I helped you somehow, please, rate it as useful.-
11-04-2019 09:58 AM
11-04-2019 10:23 AM
Run " show int " and let´s see some information like those highlighted below:
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
2 packets input, 128 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
1 lost carrier, 0 no carrier, 0 pause output
11-04-2019 10:40 AM
