184
Beginner
2600-radio-5ghz-not enabling
Hi.
Ap:model:AIR-CAP2602E-E-K9
WLC-model:5508
WLC version:8.2.166.0
error msg:
tried manually enabling the radio 5ghz to the access point from the wlc and getting the mentioned error.
This slot 1 is not operational because Regulatory Domain Check has failed! Unable to enable the Cisco AP.
allowed country codes in wlc:
AU, CN, HK, ID, IN, J4, JP, KR, MY, PH, SG, TH, US, VN
AIR-CAP2602E-C-K9 in this regulatory domain it is working.
Pls suggest what needs to be done
Anjana
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Guru
Re: 2600-radio-5ghz-not enabling
The behaviour is to be expected because you have enabled multiple countries that have CONFLICTING Regulatory Domains.
3 REPLIES 3
VIP Mentor
Hi Anjana,
Please also add a european(example: FR, DE..etc)country code as well and try again.
As AP is for europe regulatory domain so you must add atleast one european country code in WLC.
Dont forget to rate helpful posts
Highlighted
Hi Anjana,
Appropriate Country code is not enabled on this controller to support -E- domain AP.
Enable the country code based -E- domain . Refer Wireless Compliance Tool
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Hall of Fame Guru
