02-16-2018 11:33 AM - edited 07-05-2021 08:15 AM
I'm trying to configure these new 3802s we got but when I plug them in, all I keep getting is "waiting for uplink IP address and reachable default gateway"
When i do capwap ap ip address and type the ip, subnet and default gateway or just IP and subnet I get "Error: invalid ip/netmask/gateway config." nothing takes.
Any suggestions? the current VLAN doesn't assign IPs via DHCP and that's how we have all other APs (again these 3802s are new to us)
AP Running Image : 8.2.151.0
02-20-2018 03:26 AM
02-20-2018 03:42 AM - edited 02-20-2018 03:50 AM
Here's an important "gotcha": Mobility Express is a "work in progress". So use it with caution. The software is meant to be at par with a regular WLC but it's not there yet. Not even 80%.
02-20-2018 05:18 AM
02-22-2018 01:05 AM
03-23-2018 01:59 AM
Hi All,
I am running on code 8.3.133.0 and seeing the same error on few of the access point models AP3802i
-- Binish
04-17-2018 06:48 AM
04-17-2018 02:38 PM
04-17-2018 07:01 PM
Check this Feild Notice & I am sure your AP affected. There is a serial number validation tool in that page, that you can use to verify your AP hitting that issue.
If you have multiple APs, there is a form you can filled & get them RMA rather fix it manually one by one.
https://www.cisco.com/c/en/us/support/docs/field-notices/701/fn70143.html
If it is one or two APs, you can work with TAC to get it fix.
Rasika
*** Pls rate all useful responses ***
05-08-2018 05:28 AM
05-08-2018 05:37 AM
05-08-2018 06:36 AM
05-08-2018 06:51 AM
05-08-2018 07:03 AM
Hi All,
I raised TAC and issue was resolved. It indeed was the bug.
Thanks a lot.
Peter
05-10-2018 03:47 AM
What was the fix?
05-10-2018 03:55 AM
