06-03-2019 09:34 AM - edited 07-05-2021 10:30 AM
When setting up my HA pair of 5520, I can only put them in SSO if I tag the managment vlan. Our existing 5508 have untagged management vlan and when I tag the vlan on the 5520, I do not have connectivity into the gui through the management IP. I can only connect locally through the service port IP.
Solved! Go to Solution.
06-03-2019 08:58 PM
Hi @craigshawm6 ,
You have to tag the VLAN on WLC as a best recommendation for HA SSO deployment. Please refer Management Interface Vlan Tag
For an example if you have a VLAN 10 for your management. You have to tag the VLAN 10 on the WLC interface and on the switch you will be required trunk with no native VLAN as 10.
HTH,
06-03-2019 08:58 PM
Hi @craigshawm6 ,
HTH,
06-05-2019 04:07 AM
Release 8.0 onwards, it is mandatory to tag the RMI and management interfaces.
