802.1x PEAP Certificate Options
JohnTylerPearce
Level 7
Level 7
Hey, everyone!. I was pondering on getting a certificate fro ma public CA to maintain easier configuration for end users.
There will be a multitude of devices on this wireless network configured with 802.1x PEAP. (iPhones, iPADs, Droids, and PC's
of course).
If you were to get a certificate from a public CA, I'm assuming this would be just a regular server certificate from GoDaddy, or Verisgn?
Do you guys do self-signed or public certificates?
Stephen Rodriguez
Either way works, what it depends on is if the device can be told to not have to trust the server certificate.  When I had a Droid (granted it was a Droid 1), I had to hack it so that I could tell it not to trust the cert.
But I have had customers that have gone with external certs and it works perfectly fine.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
John you doing peap ?
If you do a self signed cert from the radius server you are limited to 1 year .
