Highlighted
Beginner
9800 does not have conditional web redirect is it any similar solution
after 802.1x i would like to have any conditional web redirect, but 9800 v17 does not have this feature.
any config idea to keep this conditional web redirect in 9800?
3 REPLIES 3
Highlighted
Hall of Fame Master
Redirect was only for webauth. You are authenticating using 802.1x and then you want to redirect their initial home page to a specific url?
-Scott
Highlighted
yes. after the 802.1x authen, external server will check the the end device is it have record in external server.
once the end device it will send the redirect a specific url to end device.
since in 55xx i can use conditional web redirect. 9800 cannot directly use this config.
Highlighted
Like I mentioned, this feature was only meant for webauth redirect. For the 9800, maybe you can define the redirect on the radius server to return that value to the controller. I have never heard anyone wanting to redirect a device that authenticates using 802.1x. What happens when a device gets in range and automatically connects to that ssid and only checks mail and doesn’t open a browser for a few hours?
-Scott
