About WLSE
imane
I want to know the nature of WLES (hard or soft), and where I can download it?
Thank you
Rob Huffman
Hi Imane,
Have a look at these docs;
Overview of the Wireless LAN Solution Engine
The WLSE is a hardware and software solution for managing Cisco wireless devices. The WLSE has the following major features:
Configuration and Firmware
The configuration feature allows you to apply a set of configuration changes to access points and bridges and to archive configurations. Using the firmware feature, you can upgrade the firmware on access points and bridges.
Reporting
Allows you to display reports for tracking device, client, and security information. Reports can be emailed, printed, and exported.
Fault and Policy Monitoring
Provides device monitoring for fault and performance conditions, monitoring of authentication server responses, and monitoring of policy misconfigurations.
Radio Management
Helps you manage your WLAN radio environment. All the device information shown under this tab is polled from the managed devices in your network. Radio Manager features simplify the deployment, expansion, and day-to-day management of the WLAN.
Site Management
Displays a graphical view of the WLAN environment.
Intrusion Detection System (IDS)
Displays intrusion detection information for devices in your network and allows you to manage IDS settings and set up IDS notifications.
Voice Management
Allows you to display voice call information for devices in your network, manage voice settings, and set up voice notifications.
The WLSE works by gathering fault, performance, and configuration information about Cisco devices that it discovers in your network. The devices must be properly configured for discovery. After devices are discovered, you decide which devices to manage with the WLSE.
CiscoWorks Wireless LAN Solution Engine (WLSE)
http://www.cisco.com/en/US/products/sw/cscowork/ps3915/index.html
CiscoWorks Wireless LAN Solution Engine (WLSE) Express
http://www.cisco.com/en/US/products/ps6379/index.html
User Guide for the CiscoWorks WLSE and WLSE Express, 2.13
http://www.cisco.com/en/US/products/sw/cscowork/ps3915/products_user_guide_book09186a008061ab4f.html
Hope this helps!
Rob
Please remember to rate helpful posts........
Rob Huffman
Hi Imane,
Reporting
Radio Management
Site Management
Voice Management
Hope this helps!
Rob
rmushtaq
Level 8
Level 8
WLSE is an appliance, which mean that the software comes loaded on a piece of hardware. You cannot just download and install the software on any other box. See http://www.cisco.com/en/US/products/sw/cscowork/ps3915/ for more details.
thanks for help me ;-)
