08-22-2011 12:38 AM - edited 07-03-2021 08:36 PM
Hi all,
I have a customer with an ACS for Windows version 3.3. I know the ACS is End-of-support, but is anybody who know if I could do Authentication for a WLAN with a Controller 5508 Softwareversion 7.0.116.0 and how?
Kind regards
Holger
Solved! Go to Solution.
08-22-2011 01:00 AM
Release notes states that the ACS 4.2 is mandatory for WLC running 7.0.116
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_0_116_0.html#wp274399
3.3 is not supported..
Lemme know if this answered ur question and Please dont forget to rate the usefull posts!!
Surendra
08-22-2011 01:00 AM
Surendra
08-22-2011 02:26 AM
Hi Surendra,
the release notes told that ACS 4.2 or later is tested, but not that the version is mandatory. If you say that version 4.2 is mandatory I will accept this.
Regrads
Holger
08-22-2011 06:28 AM
few weeks back faced a EAP FAST issue on the ACS running 3.3 and WLC 7.0.116, finally upgraded the ACS to 4.2 and everything worked fine!!
Surendra
