03-09-2011 11:28 AM - edited 07-03-2021 07:56 PM
Hi All,
i try to Access ACS5.2 installed on VM via SSH. I used 3 different SSH Clients, Teraterm, Sec CRT and Putty, all failed. Putty failed after (correct) password, Teraterm and SCRT failed with a Popup and the List of ACS Supported Modes (DH Group 14, AESxxxCBC ...). I configured them in the Options, but failed again. Very frustrating...
Any Help Welcome.
Regards, Michael
Solved! Go to Solution.
03-09-2011 02:29 PM
Is this a new install? Can you look at the VM console and is all the services running. Is it just with ssh or can you https to ACS?
03-09-2011 02:29 PM
03-10-2011 12:12 PM
Thanx Scott, since the Engine was very Fresh i recovered it. Regards, Michael
06-03-2011 04:07 AM
Michael,
Could you please mark this question as answerd since the issue is resolved?
thanks,
Vinay
09-08-2015 12:22 AM
May i know how it got resolved.
I am facing the same problem. I not able to SSH to my ACS 5.2
It prompts me for the username & password. It is not accepting the credentials.
