10-10-2006 12:04 AM - edited 07-04-2021 01:17 PM
I am hoping to implement PEAP using a server certificate on ACS generated from a real CA like Verisign/Thawte etc to prevent having to distribute an internal root CA certificate to all clients.
I have discovered that Verisign provide a WLAN Auth certificate product , but this appears to be specificlly for IAS.
Does anybody know whether I can just generate a certificate reest from the ACS box and use any certificate , or is there a particular type I need?
Any help would be much appreciated!
Leon
10-17-2006 05:17 AM
CTA can be configured to perform machine authentication using certificates provided that the 802.1x Wired Client has been installed.Refer http://cisco.com/en/US/products/ps5923/products_maintenance_guide_chapter09186a00806870ac.html for more information.
10-17-2006 06:52 AM
Yes you can generate a cert request from the ACS server and submit it to an online CA. One I've used several times with no problems is www.rapidssl.com . The whole process takes only a few minutes and a 5 year cert is about $350 which is pretty good value.
