AeroScout Engine Not Loading
dpita3186
We have an MSE 3350 with the AeroScout Engine for Tag Tracking.  I've performed the steps listed in this thread: https://supportforums.cisco.com/message/3058630.
However when moving the server-eng.db file, the Context Aware service will not track any elements, and our WCS will not reach the MSE, but the AeroScout Engine turns to "active:true"
Please adivse on how we can proceed.
7 Replies 7
Nael Mohammad
Level 5
Level 5
post the "getserverinfo" from the mse cli and get the MSE logs and all the logs under /opt/mse/logs in zip format.
Hi Nael,
Attached are the log files and below is the getserverinfo output:
~]# getserverinfo
MSE Platform is up, getting the status
Server Config
Product name: Cisco Mobility Service Engine
Version: 7.0.105.0
Hw Version: V01
Hw Product Identifier: AIR-MSE-3350-K9
Hw Serial Number: MXQ03108G4
Use HTTP: false
Legacy HTTPS: true
Legacy Port: 8001
Log Modules: 520617983
Log Level: INFO
Days to keep events: 2
Session timeout in mins: 30
DB backup in days: 2
Services
Service Name: Context Aware Service
Service Version: 7.0.105.0
Admin Status: Enabled
Operation Status: Up
Service Name: Wireless Intrusion Protection Service
Service Version: 1.0.2066.0
Server Monitor
Server start time: Thu Oct 07 16:15:34 EDT 2010
Server current time: Sat Oct 09 09:02:00 EDT 2010
Server timezone: America/New_York
Server timezone offset: -18000000
Restarts: 16
Used Memory (bytes): 628499400
Allocated Memory (bytes): 1477902336
Max Memory (bytes): 1477902336
DB virtual memory (kbytes): 27026
DB virtual memory limit (bytes): 0
DB disk memory (bytes): 6656032768
DB free size (kbytes): 738584
Active Sessions
Session ID: 14621
Session User ID: 3
Session IP Address: 10.10.205.21
Session start time: Thu Oct 07 16:16:28 EDT 2010
Session last access time: Sat Oct 09 09:00:49 EDT 2010
Total Active Elements(Clients, Rogues, Interferers): 1032
Active Clients: 712
Active Tags: 0
Active Rogues: 320
Active Interferers: 0
Active Wired Clients: 0
Active Elements(Clients, Rogues, Interferers) Limit: 3000
Active Tag Limit: 100
Active Wired Clients Limit: 0
Active Sessions: 1
Clients Not Tracked due to the limiting: 0
Tags Not Tracked due to the limiting: 0
Rogues Not Tracked due to the limiting: 0
Interferers Not Tracked due to the limiting: 0
Wired Clients Not Tracked due to the limiting: 0
Total Elements(Clients, Rogues, Interferers) Not Tracked due to the limiting: 0
Context Aware Sub Services
Sub Service Name: aeroscout
Version: 3.2.0 - 4.0.14.14
Description: AeroScout® Location Engine for RSSI and TDOA asset tracking
Active: false
Engine flap Count: 0
Failed Connection attempts: 369
What version of WCS ?
WCS Version is 7.0.164.0
dpita3186
The issues persist, the failed connection attempts have increased.  Here is the latest getserverinfo:
# getserverinfo
Server Config
Version: 7.0.105.0
Hw Version: V01
Use HTTP: false
Legacy HTTPS: true
Legacy Port: 8001
Log Level: INFO
Services
Server Monitor
Server current time: Wed Oct 20 09:06:35 EDT 2010
Restarts: 16
Used Memory (bytes): 890585880
Allocated Memory (bytes): 1451425792
Max Memory (bytes): 1451425792
DB virtual memory (kbytes): 30250
DB disk memory (bytes): 7127072768
DB free size (kbytes): 366912
Active Sessions
Session ID: 14621
Session User ID: 3
Session last access time: Wed Oct 20 09:03:23 EDT 2010
Total Active Elements(Clients, Rogues, Interferers): 2840
Active Clients: 2495
Active Tags: 0
Active Rogues: 345
Active Sessions: 1
Active: false
Engine flap Count: 173
Failed Connection attempts: 4088
Hi.
First of all; review the Aeroscout compatibility; you are using an older version of Aeroscout Engine:
For MSE 7.0.105.0 you may use the Aeroscout engine 4.2.3.5 which is the only version Aeroscout have certified; refer to the AeroScout Version Compatibility With Cisco MSE (article 1100 from Aeroscout)
Then, you have to license the Engine using the Aeroscout System Manager when the engine will be up and active.
Good luck
Best Regards.
I have got the same problem !
./msed status
STATUS:
Server Config
Version: 7.0.105.0
Hw Version: V01
Hw Serial Number: MXQ034020V
Use HTTP: false
Legacy HTTPS: false
Legacy Port: 8001
Log Modules: 24516
Log Level: INFO
Days to keep events: 7
DB backup in days: 7
Services
Server Monitor
Server start time: Thu Jan 06 21:36:29 CET 2011
Server current time: Thu Jan 06 22:19:32 CET 2011
Server timezone: Europe/Amsterdam
Server timezone offset: 3600000
Restarts: 11
Used Memory (bytes): 109683888
Allocated Memory (bytes): 512163840
Max Memory (bytes): 2863333376
DB virtual memory (kbytes): 16364
DB disk memory (bytes): 974880768
DB free size (kbytes): 144072
Active Sessions
Session ID: 6185
Session User ID: 2
Session IP Address: x.x.x.x
Session start time: Thu Jan 06 21:39:38 CET 2011
Session last access time: Thu Jan 06 22:17:26 CET 2011
Total Active Elements(Clients, Rogues, Interferers): 3839
Active Clients: 2445
Active Tags: 0
Active Rogues: 1394
Active Elements(Clients, Rogues, Interferers) Limit: 12005
Active Sessions: 1
Active: false
Failed Connection attempts: 19
I have installed the latest 'CISCO-MSE-L-K9-7-0-105-0-64bit.bin.gz' with Release Date: 06/JUN/2010.
I Tried :
1. ./msed stop.
2. mv /opt/mse/db/linux/server-eng.db /opt/mse/db/linux/server-eng.db.old
:  ,mv: cannot stat `/opt/mse/db/linux/server-eng.db': No such file or directory>>> !!!
# pwd
/opt/mse
# ls -al
total 1848
drwxrwxr-x 13 root root    4096 Dec  3 18:51 .
drwxr-xr-x  4 root root    4096 Dec  3 18:45 ..
-rw-------  1 root root       0 Jan  6 21:36 0
drwxrwxr-x  2 root root    4096 Dec  3 18:45 attach
-rw-rw-r--  1 root root 1828881 Dec  3 18:48 Cisco_Mobility_Services_Engine_InstallLog.log
drwxrwxr-x  4 root root    4096 Dec  3 18:59 dataFiles
drwxrwxr-x  8 root root    4096 Dec  3 18:45 framework
drwxrwxr-x  4 root root    4096 Dec  3 18:46 hs
drwxr-xr-x  6 root root    4096 Nov 15  2006 jre
lrwxrwxrwx  1 root root      38 Dec  3 18:48 licensing -> /opt/mse/dataFiles/framework/licensing
drwxrwxr-x 13 root root    4096 Dec  3 19:00 locserver
drwxr-xr-x  7 root root    4096 Dec  3 18:45 logs
drwxrwxr-x  2 root root    4096 Dec  3 18:45 rpms
drwxrwxr-x  3 root root    4096 Dec  3 18:45 setup
drwxrwxr-x  2 root root    4096 Dec  3 18:48 uninstall
drwxrwxr-x 14 root root    4096 Dec  3 18:52 wips
There is no directory 'db' ........
3. start msd again : ./msed start
Can you help me ?>
Thanks !
