AIR-CAP2702I-A-K9 not connecting to WLC 5508
GavinDowd3340
I have inherited some 2702i's. I reset the config using a console cable. When they reboot they detect our WLC and download all the configuration file - I can see them on the controller whilst they are doing this.
They then reboot and refuse to reconnect. They just constantly repeat this same error:
*May 7 11:00:28.607: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*May 7 11:00:28.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.227.245 peer_port: 5246
*May 7 11:00:28.447: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.227.245 peer_port: 5246
*May 7 11:00:28.447: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.227.245
*May 7 11:00:28.487: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_record.c:169 Pkt too old last_seq_num : 1,Received sequence num: 1 distance: 0
I have tried searching for answers on the internet without any success. In desperation I even erased the flash: and reinstalled the image from TFTP but it is still doing the same.
Product/Model Number : AIR-CAP2702I-A-K9
Regulatory Domain of the AP is "-A" (USA).
Configured Country............................... GB - United Kingdom
Regulatory Domain configured on the WLC is UK.
This is why the AP won't join:  Regulatory Domain Mismatch.
The AP needs to have a Regulatory Domain of "-E" to match.
Is also explains why the AP can/will download the config from the WLC but is unable to join the controller.
8 Replies 8
GavinDowd3340
I forgot to mention if I get a brand new 2702i out of the box and plug it into the same network point it registers itself just fine so it is something on these second hand AP's however I can't think what it can be as I have erased both the NVRAM and FLASH but still have this problem
Leo Laohoo
Post the complete output to the following commands:
  1. AP:  sh version;
  2. AP:  sh ip interface brief;
  3. WLC:  sh sysinfo; and
  4. WLC:  sh time
AP2cd0.2da3.9028#
AP2cd0.2da3.9028#sh ver
Cisco IOS Software, C2700 Software (AP3G2-K9W8-M), Version 15.3(3)JF7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 05-Jun-18 05:05 by prod_rel_team
ROM: Bootstrap program is C2700 boot loader
BOOTLDR: C2700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB5m, RELEASE SOFTWARE (fc2)
AP2cd0.2da3.9028 uptime is 31 minutes
System image file is "flash:/ap3g2-k9w8-mx.153-3.JF7/ap3g2-k9w8-xx.153-3.JF7"
Last reload reason: Power Loss
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP2702I-A-K9 (PowerPC) processor (revision A0) with 376814K/134656K bytes of memory.
Processor board ID FCW2051NNJ1
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.5.131.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 2C:D0:2D:A3:90:28
Part Number : 73-15824-04
PCB Serial Number : FOC20510JAK
Top Assembly Part Number : 068-100373-02
Top Assembly Serial Number : FCW2051NNJ1
Top Revision Number : A0
Configuration register is 0xF
AP2cd0.2da3.9028#sh ip interface brie
BVI1 172.16.61.8 YES DHCP up up
Dot11Radio0 unassigned NO unset up up
Dot11Radio1 unassigned NO unset up up
GigabitEthernet0 unassigned NO unset up up
GigabitEthernet1 unassigned NO unset administratively down down
VIOS_FABRIC0 unassigned YES unset up up
Virtual-WLAN0 unassigned NO unset up up
Virtual-WLAN0.1 unassigned NO unset up up
Virtual-WLAN0.2 unassigned NO unset up up
Virtual-WLAN0.3 unassigned NO unset up up
Virtual-WLAN0.4 unassigned NO unset up up
Virtual-WLAN0.5 unassigned NO unset up up
Virtual-WLAN0.6 unassigned NO unset up up
Virtual-WLAN0.7 unassigned NO unset up up
Virtual-WLAN0.8 unassigned NO unset up up
Virtual-WLAN0.9 unassigned NO unset up up
Virtual-WLAN0.10 unassigned NO unset up up
Virtual-WLAN0.11 unassigned NO unset up up
Virtual-WLAN0.12 unassigned NO unset up up
Virtual-WLAN0.13 unassigned NO unset up up
Virtual-WLAN0.14 unassigned NO unset up up
Virtual-WLAN0.15 unassigned NO unset up up
Virtual-WLAN0.16 unassigned NO unset up up
AP2cd0.2da3.9028#
(Cisco Controller) show>sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.131.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.95.16
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... TGH-WLC5508
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. SSO
IP Address....................................... 172.16.227.245
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 84 days 20 hrs 44 mins 22 secs
System Timezone Location......................... (GMT) London, Lisbon, Dublin, Edinburgh
--More-- or (q)uit
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +37 C
External Temperature............................. +20 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 16
Number of Active Clients......................... 878
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ F4:CF:E2:95:0B:80
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 500
System Nas-Id.................................... B15_WLC5508-01
WLC MIC Certificate Types........................ SHA1/SHA2
--More-- or (q)uit
(Cisco Controller) show>time
Time............................................. Thu May 7 12:15:21 2020
Timezone delta................................... 0:0
Timezone location................................ (GMT) London, Lisbon, Dublin, Edinburgh
NTP Servers
NTP Version.................................. 3
NTP Polling Interval......................... 600
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 0 172.16.8.1 In Sync AUTH DISABLED
Is there a way to change domain on the AP or have the WLC accept American AP's ?
You cant chnage the AP domain.
Just change the country code on WLC to US and then try again.
Dont forget to rate helpful posts
Thanks I did that and they are working fine now.
Thanks for your help
Presume you're aware that it would be illegal to use APs from a different regulatory domain in UK?
Obviously if you're actually using them in the US then that's fine.
