12-19-2012 10:34 AM - edited 07-03-2021 11:15 PM
Greetings!
I am in need of some assistance with the implimentaion of the AirCap 3602i wireless access points.
1. Is there a way to manually configure a AirCap 3602i to function without a WAN controller?
2. I have an older 4402 WAN controller that will upgrade to 7.0.235 firware, since the AIrCap 3602i requires 7.2.X firmware, is there a workaround for this?
Thank you very much for any information you may provide.
CK
12-19-2012 11:13 AM
Hello Mark,
Look:
1 - Yes, you need check if you are using one Autonomous IOS.
2 - I check here you are right the min release 7.1.91.0 to running and I'm not sure to say if work on 7.0.235.3. I think not.
Regards.
12-19-2012 11:23 AM
Mark
If you're asking does a 3600 support autonomous yes and no ..
https://supportforums.cisco.com/docs/DOC-20537
It's support for site survey ..
Hope this helps
12-19-2012 01:31 PM
An autonomous IOS for the 1600/2600/3600 is now available. There are currently two versions of the 15.2(2). Please DO NOT use the JA version if you want to do 802.1Q trunking.
One thing good about the new 15.2(2) aIOS is the newly redesigned configuration GUI. So go ahead and check it out.
PS: You cannot run the 3600 on a 4400 controller. There is no workaround now. There is no workaround in the future. The 4400 does not have enough grunt to support the 7.1.X or 7.2.X firmware. This is one of the reasons.
12-19-2012 01:36 PM
Leo -- Is this now offically supported or still only survey mode?
__________________________________________________________________________________________
"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
12-19-2012 03:48 PM
Hi George
here you go.
15.2.2JB
http://www.cisco.com/en/US/docs/wireless/access_point/ios/release/notes/15.2_2_JB.html#wp355587
Support for AP1550, AP3500E, AP3500I, AP3600E, and AP3600I,
This release provides complete software functionality to AP1550, AP3500E, AP3500I, AP3600E, and AP3600I series access points.
15.2.2JA
http://www.cisco.com/en/US/docs/wireless/access_point/ios/release/notes/15_2_2_JArn.html#wp288972
Support for Cisco Aironet 2600 Series Access Points
This release supports standalone Cisco Aironet 2600 Series Access Points. Detailed information and configuration procedures for autonomous (standalone) access point are in Chapter 6
Site-Survey Only Mode for 3600, 3500, and 1550 Access Points
You can install Cisco IOS Release 15.2(2)JA on Cisco Aironet 3600 and 3500 Series access points and on 1550 series outdoor access points to perform site surveys.
12-19-2012 03:53 PM
+5 .. When was this released ?
12-19-2012 03:56 PM
17-DEC-2012, couple of days ago. The gui mimic the wlc.
12-19-2012 06:51 PM
Hi Saravanan,
The newly released 7.4 code, does it bring the WiSM-2 base-ap-count to 1500? I can see it in "Licenses" but I can't get an answer from our SE.
12-19-2012 10:06 PM
Hi Leo
7.4 release notes doesn't mention about it. also i checked the other day and was told there is no change in ap support limit for wism2. please share the link that shows 1500.
also, i checked the wism2 datasheet and couldn't see 1500 unless i'm missing something.
12-20-2012 02:41 PM
Hi Saravanan,
Look below.
12-20-2012 02:52 PM
Leo
I see youre still posting and its 12/21 so the world didnt end ..
Since we are on the subject of WISM2, does it create 1 or 2 chanel groups ? I plugged in the WISM 2 it shows 2 channel groups but only 1 being used ..
12-20-2012 03:04 PM
I got to distro ports since upgraded to 7.3 (if memory serves me correct). Currently, with 7.4, I've got both UP/UP.
We're ahead of the Internation Date Line. This is the Mayan Calendar so we'll know tomorrow.
12-20-2012 03:18 PM
Sorry -- i dont understand ..
So you have 2 channel groups or no?
12-20-2012 03:25 PM
You're right. I have a single 10 Gbps etherchannel. Don't know what happened to the second link.
