01-25-2019 04:12 PM - edited 07-05-2021 09:45 AM
Hi Everyone!
I have a workgroup-bridge scenario where a 1572 ap is the root and an 1532 the wgb client, attached to the 1532 ap we have some axis cameras, the thing is that the 1532 ap is ok untill someone tries to access the cameras, then the access points reloads this issue is driving me crazy haha. Does anyone has ever had some issue like this before?
Kind Regards!
01-25-2019 10:50 PM
- If possible, monitor the console AP and or try to capture the reason of the reboot ; also check current software version being used by the AP. Compare with more recent releases if applicable (upgrade).
M.
01-28-2019 08:18 AM
The current version of the ap is ap1g3-k9w7-tar.153-3.JI1.tar
01-29-2019 01:18 AM
01-29-2019 07:46 AM
Since the ap are in autonomous mode, there is no avc configuration capability right? but anyways, i'll give it a check and let you know, and ill try to upgrade the ap, but the weird thing is that the rest of the ap on the warehouse have the same code version and no other behaves like that!
BR!
01-29-2019 08:02 AM
01-26-2019 06:07 AM
11-21-2019 01:10 PM
Yup thanks,
there was a damaged hardware!
thanks!
