02-10-2019 11:42 AM - edited 07-05-2021 09:49 AM
I have a wireless AP 2800 which is not getting an IP address from the Primary controller name and IP
All my other APs are working ok to the same controller namely 10.4.3.11
Incidently its stuck on a green light even after a reboot
I can ping the 10.4.3.11 address from the device ok
AP Name : AP-01
Admin State : Enabled
AP Mode : FlexConnect
AP Submode : None
Reboot Reason : Controller Reload command
Primary controller name :
Primary controller IP : 0.0.0.0
Controller from DHCP offer : 10.224.3.11
AP join priority : 1
Thanks Kevin
Solved! Go to Solution.
02-11-2019 04:43 AM
As mentioned by other users in the forum, you will need to console on to the AP, reload it and capture the logs for us. I'm sure the info generated from the logs will be enough for us to help you out.
02-11-2019 02:11 PM
Got it sorted
The AP was pointing to the secondary controller and not the primary controller. Once i changed the AP on the secondary WLC to point back to the Primary WLC it was fine. Cisco tech did check the logs first on the remote controller before deciding to check the entry on the secondary WLC
Thanks to everyone on this page for advice - it all helped
02-10-2019 12:50 PM - edited 02-10-2019 12:53 PM
Console on to the AP and add the following:
capwap ap controller-name controller-ip-address
If the AP still don’t’ want to join the WLC, run a capwap event debug so we can get more information.
<<< Please help the community by marking useful posts helpful, or accept as a solution if it resolved your issue >>>
02-10-2019 02:35 PM
It wont take the command
capwap ap NIW-WLC-W 10.4.3.11
any ideas
02-10-2019 02:39 PM
02-10-2019 01:51 PM
02-10-2019 02:31 PM
Other sites are working ok but not this site. Both APs at this site are doing the same thing
02-10-2019 02:52 PM
02-10-2019 03:09 PM
Yes - i have that in place and it works for other sites but not this one. I can ping it ok
ip dhcp pool Wireless_APs
network 10.3.16.128 255.255.255.128
default-router 10.3.16.129
dns-server 10.8.4.5
option 43 hex f104.0ae0.030b
02-10-2019 08:24 PM
02-10-2019 09:44 PM
your heading is little confusing, do you mean the AP is not able to join primary controller or AP is not even getting an IP address ?
based on the switch config as DHCP, if you do show ip dhcp binding, you can check if the AP has got an IP to start with.
As mentioned by everyone, AP console output will be helpful.
02-11-2019 01:56 AM
the AP is getting an IP address ok and i can ping the AP across the network and login to it
sh ver
cisco AIR-AP2802I-E-K9
AP Running Image : 8.3.102.0
Primary Boot Image : 8.3.102.0
Backup Boot Image : 8.2.151.0
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
02-11-2019 04:43 AM
02-11-2019 08:46 AM - edited 02-11-2019 02:07 PM
I have rebooted it and here is the logs from it booted up
Its trying to join the backup controller on 10.224.3.11 which is not right
AP has joined controller NIW-WLC-BRET
It should be 10.224.2.13 and NIW-WLC-BRET
02-11-2019 02:11 PM
Got it sorted
02-11-2019 04:51 AM
