09-26-2011 07:43 AM - edited 07-03-2021 08:49 PM
Occasionally WCS will throw the following error:
AP Impersonation of MAC 'Redacted' using source MAC 'Redacted' is detected by authenticated AP 'Redacted' on '802.11b/g' radio and Slot ID '0'.
We are running version 7.0.172.0 and the only thing I can find about this error indicated that I should check the controller. When I look on the controller I do not see the error in the syslog. Does anyone have an idea of what could be causing this error?
09-26-2011 08:04 AM
Generally, this error indicates the WLC is detecting a device that is spoofing a known MAC address. take a look at
http://www.cisco.com/en/US/products/ps6305/products_tech_note09186a00806f070a.shtml#APIMP
This is a bit older, but gives some informatio on the error.
HTH,
Steve
09-27-2011 07:38 AM
I checked the APs primary controller and did not see the error indicated anywhere in the logs. I even checked the secondary and tertiary controllers to no avail.
09-27-2011 05:39 PM
Ive chased this same error and I am 99.9% certain this is a bug, just my 2 cents. I know there is no way I have another device taking the MAC of one of my APs. Even after hours of L2 captures, nothing ...
I opened a TAC last year and got the anwser Steve gave you.. I dont buy Cisco kool-aid on that one...
09-28-2011 09:01 AM
I think it might be a bug as well.
