09-20-2019 03:30 AM - edited 07-05-2021 11:01 AM
Hi team,
I pulled report from NCS for AP utilization, it gives multiple instance for same AP in AP Client statistics summary. ANy specific reason why its giving multiple instance. We are fine if its give two, becaus eof readio but single AP gives for instance or five instance
09-20-2019 10:01 AM
Can you attach an example. Not clear to me what do you mean by instance.
-If I helped you somehow, please, rate it as useful.-
09-23-2019 01:28 AM - edited 09-23-2019 01:29 AM
Hi @Flavio Miranda ,
Same AP with five entries.
09-23-2019 12:54 PM
As per the logs, everything looks fine. I´m seeing AP bb18 with 2 radius, AP 54e0 with 2 radius and AP 4b3c with 2 radios. Then, AP 3aa4 with only 5.0 Ghz radio and AP 57b4 with 5.0 Ghz radio.
Did you attach the right report ?
AP Client Statistics Summary | ||
AP Name | AP MACAddress | Radio Type |
AP00a3.8e75.bb18 | 00:27:e3:62:75:b0 | 802.11b/g/n |
AP00a3.8e75.bb18 | 00:27:e3:62:75:b0 | 802.11a/n/ac |
AP00c8.8b92.3aa4 | 00:8e:73:45:f0:c0 | 802.11a/n |
AP00c8.8b92.54e0 | 00:ca:e5:85:94:40 | 802.11b/g/n |
AP00c8.8b92.54e0 | 00:ca:e5:85:94:40 | 802.11a/n |
AP502f.a899.4b3c | 00:ea:bd:19:52:10 | 802.11b/g/n |
AP502f.a899.4b3c | 00:ea:bd:19:52:10 | 802.11a/n/ac |
AP502f.a899.57b4 | 00:ea:bd:19:83:a0 | 802.11a/n/ac |
09-25-2019 05:49 AM - edited 09-26-2019 11:23 PM
Please find attached correct report
09-30-2019 06:46 AM
Can you please help, why we are seeing multiple entries for same AP. Attaching logs
09-30-2019 08:10 AM
10-08-2019 12:45 AM
Hi @patoberli
Yes we have multiple SSIDs.
