Ask the Experts: Wired Guest Access
ciscomoderator
Community Manager
Community Manager
Sharath K.P.
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn and ask questions on wired guest access with expert Sharath K.P. Wired guest access enables guest users to connect to the guest access network from a wired Ethernet connection designated and configured for guest access. Sharath K.P. is a Customer Support Engineer specialized in wireless and switching technologies at the Technical Assistance Center in Cisco Bangalore. He has been troubleshooting wireless and switching networks and management tools since 2009. Sharath has a bachelor's degree in Electrical Electronics Engineering from P.E.S College of Engineering (PESCE), VTU at Belgaum. India. He holds CCNP certifications in R&S and Wireless.
Remember to use the rating system to let Sharath know if you have received an adequate response.
Sharath might not be able to answer each question due to the volume expected during this event.
Remember that you can continue the conversation on the Wireless and Mobility sub-community discussion forum shortly after the event. This event lasts
through January 27, 2012.
Visit this forum often to view responses to your questions and the questions
of other community members.
44 Replies 44
craigs
Is there any way currently (or future road map) to have the ability to centralize guest wired access from a H-REAP AP across a layer 3 network?
Craigs,
Can we use the following example to clarify your question?  (please modify as needed)
Let's say you have a controller with four WLANs.
#1 = "Jayhawk", which is centrally switched, and PEAP
#2 = "KU-Tickets", which is locally switched, and WPA-PSK for ticket scanners
#3 = "KU-Guest", which is a centrally switched guest network back to the anchor controller in the DMZ
#4 =  Wired guest network.  This is also centrally switched back to the anchor in the DMZ.. say VLAN 555
The H-REAP AP broadcasts three SSIDs:
One SSID is locally switched for whatever reason.
One SSID is centrally switched to the routed infrastructure.
The guest SSID is centrally switched, however the controller shoves it to the anchor in the DMZ.
The controller is tunneling VLAN 555 back to the DMZ controller.
The guest wireless network uses an AUP webauth bundle on the Anchor controller.
Can we go from here with the discussion?
tdennehy,
It appears you are a Kansas fan and for that I am sorry
In your example I've got a single port at the remote branch office that I'd like to run through the centralized controller (say Vlan 555) as the Guest Wired LAN network and AUP Authentication.  Is this possible if the office is connected across a layer 3 network?  In other words I'd like Vlan 50 (Wired Guest Network that's Local at the branch) to be tunneled to the Wireless Controller for AUP agreement.
Make Sense?  Is this Possible?
Craig
Hi Craig ,
Currently we are not supporting the feature you have requested .
Configuration Guidelines
Follow these guidelines before using wired guest access on your network:
Wired  guest access is supported only on the following controllers: 5500 and  4400 series controllers, the Cisco WiSM, and the Catalyst 3750G  Integrated Wireless LAN Controller Switch.
Wired guest access interfaces must be tagged.
Wired guest access ports must be in the same Layer 2 network as the foreign controller.
Up to five wired guest access LANs can be configured on a controller.
Layer 3 web authentication and web passthrough are supported for wired guest access clients. Layer 2 security is not supported.
Do  not attempt to trunk a guest VLAN on the Catalyst 3750G Integrated  Wireless LAN Controller Switch to multiple controllers. Redundancy  cannot be achieved by doing so.
Regards ,
Sharath K.P.
Sharath,
This statement "Do not attempt to trunk a guest VLAN on the Catalyst 3750G Integrated
Wireless LAN Controller Switch to multiple controllers. Redundancy cannot be achieved by doing so."
What exactly is that saying?
Should that really read, "Do not attempt to trunk a guest VLAN on any Catalyst switch to multiple controllers. Redundancy cannot be achieved by doing so"?
I don't understand whtat the first statement says. If I did have a 3750G integrated switch, is it stating that you could not take two 3750G integrated switches and trunk them together for redundancy? If so, why does it specifically state the 3750G integrated swtich and not all switches in general.
Can you please clarify?
Thanks in advance!
Hi Tdennehy ,
As we have discussed previously (Post on 17- Jan),one of the changes requested as per of fixing the statement CSCtw44999 is to correct this statement in the document .
Where it says "Do not attempt to trunk a guest VLAN on the Catalyst 3750G ...", this should read:
"Do not trunk a wired guest VLAN to multiple foreign controllers.  This is not supported, and will
generate unpredictable results."
Regards ,
Sharath K.P.
HI Criag ,
To answer the question , I will need more details on what kind of design you are trying to accomplish .
Can you add more details .
Regards ,
Sharath K.P
Hi Craig .
We dont have this plan included in any of the future releases .
However we will take this as a ehancement request .Updates will follow
Regards ,
Sharath K.P.
Hello Sharath,
Is there a document with the specifications of the maximun number of guess access users that we support in the different WLC platforms and will also like to know how to manage the users from WCS?
- Lisa
Something I have always wondered is along the same lines as what Lisa asked.
Is there a way to carve a guest anchor controller up so that each controller that tunnels their guest users to it gets a specific range of IP addresses?
Reason I'm asking is many organizations are seeing an exponential increase in the number of guest users. If there was a way to abandon "everyone gets an IP address from this one pool" and carve up the anchor in the DMZ so that each site/controller that tunneled to it gets a specific range of IP address, that would be an awesome document. I would love any suggestions anyone has...
HI Tdennehy ,
You can check this link and let me know  if this  helps .
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080b78900.shtml#apply
In current WLC architecture, it is mandatory to  map the WLAN to an interface/VLAN. Default mapping is to management  interface. The limitation is that one WLAN can be mapped to a single  interface/VLAN. This limitation requires availability of a single large  subnet, in dense deployments, which might not be feasible for many  customers because of existing network design and IP subnet allocation in  their network. Existing features, such as AP Groups
and AAA override,  can help to some extent but cannot meet complete requirements and might  not be feasible in all kinds of customer deployments. This same  limitation also exists to the guest anchor setup where guest clients on  remote locations always get an IP address from a single subnet mapped to  the WLAN on anchor location. Also, the IP address assignment to  wireless guest clients is not dependent on foreign locations and all  guest clients on different foreign locations will receive an IP address  from the same subnet. Once again, this is not feasible for many  customers.
Integration of VLAN Pooling, or the VLAN Select feature, in the  7.0.116.0 release provides a solution to this restriction where the WLAN  can be mapped to a single interface or multiple interfaces using  interface group. Wireless clients associating to this WLAN will receive  an IP address from a pool of subnets identified by the interfaces in  round robin fashion.
This flowchart illustrates the DHCP address selection when the round  robin mechanism is used in interface or interface group configuration:
Note: If the DHCP lease time is high, there is a possibility  of DHCP IP leakage if the clients frequently de-authenticates and  re-authenticates.
Note: With Inter-Release Controller Mobility (IRCM),  controllers in releases before 7.0.116.0 cannot understand the VLAN list  payload. Therefore, sometimes a L3 mobility is performed where L2  mobility could have been done.
Note: If you want to downgrade from the 7.0.116.0 release to a  previous release, make sure that all WLANs are mapped to interfaces and  not interface groups, and multicast interface is disabled.
Note: Cisco does not support an interface group being returned from AAA, only interface.
Note: Interfaces can be added to an interface group but cannot be deleted when it is mapped to the WLAN/AP Group.
Note: One VLAN or interface can be a part of many different interface groups.
The VLAN Select feature also extends current AP group and AAA  override architecture where AP groups and AAA override can override the  interface the WLAN is mapped to. This feature also provides the solution  to guest anchor restrictions where now wireless guest user on foreign  location can get an IP address from multiple subnets based on their  foreign locations/foreign controllers from same Anchor WLC.
This flowchart indicates WLAN selection when AP group and AAA  override are configured on the controller and WLAN has been mapped to an  Interface or Interface Groups:
Hi Lisa ,
Welcome to the discussion .
The local database on the WLC stores entries for these items
  • Local management users (including lobby ambassadors)
  • Local network users (including guest users)
  • MAC filter entries
  • Exclusion list entries
  • Access point authorization list entries
The local user database is limited to a maximum of 2048 entries. The  valid range is 512 to 2048, and the default setting is 2048. Together  they cannot exceed the configured maximum value.
The database size can be configured using the WLC CLI or the GUI.
In order to configure the local database using the CLI, enter this command:
config database size
Examples:
(Cisco Controller) >config database size ?
        Enter the maximum number of entries (512-2048).
Please save the configuration and reset the system ("reset system") for the change to take effect.
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080a49cd7.shtml
Regarding guest user management using WCS ,you can check this link .
http://www.cisco.com/en/US/docs/wireless/wcs/4.0/configuration/guide/wcsmanag.html#wp1075024
Creating Guest User Accounts
You can use the Cisco Lobby Ambassador feature to create guest user  accounts in WCS. A guest network provided by an enterprise allows access  to the internet for a guest without compromising the security of the  host. The web authentication is provided with or without a supplicant or  client, so a guest needs to initiate a VPN tunnel to their desired  destinations.
The system administrator must first set up a lobby administrator  account, also known as a lobby ambassador account. A lobby ambassador  account has limited configuration privileges and only allows access to  the screens used to configure and manage guest user accounts. The lobby  administrator has no access to online help.
This account allows a non-administrator to create and manage guest user  accounts on WCS. The purpose of a guest user account is to provide a  user account for a limited amount of time. The lobby ambassador is able  to configure a specific time frame for the guest user account to be  active. After the specified time period, the guest user account  automatically expires. This section describes how a lobby ambassador can  create and manage guest user accounts on WCS.
Geza Makay
Hi Sharath,
I hope this is the right place for this question as it is related to allow guest (i.e. limited) access to the network.
I have an SG300-20 here for testing (firmware: 1.1.2.0, boot version: 1.0.0.4, language version: 1.1.1.6 English). Everything seems to work on it, except, that if I choose Radius authentication by mac address only, then the switch does not honor the Idle-Timeout and Session-Timeout attributes from the Radius server (freeradius).
The setup is the following: I have a no name access point plugged in to switch port gi1 (I know this discussion is about wired net, but from the switch's point of view it is a wired access). The port gi1 is set up for Radius authentication by mac address only. The access point itself is authenticated, no problem with that. If I connect through the access point by (say) a mobile phone, it is authenticated, no problem. The radius server does send the Idle-Timeout and Session-Timeout attributes, I checked it by running "freeradius -X", both are set to 30 seconds. Then I turn off the wireless card in my mobile phone and check the dot1x users by "show dot1x users". My mobile phone's mac address remains there for 5-10 minutes, so the Idle-Timeout and Session-Timeout  does not work.
Another way I could resolv this problem is by explicitely asking the switch to reauthenticate the user. Unfortunately there is no CLI command to do just that, I can do however a reauthentication on a port using "dot1x re-authenticate gi1" (for example). But it does not work as it is expected: the switch uses the stored mac-address to reauthenticate the user, so nothing changes on the port (unless something changes in the radius server). I think it should work like the following: remove the authenticated user from the port, and whenever that mac address makes some network traffic, then reauthenticate as if it were a completely new connection. BTW: it would help me also if I could just remove an authenticated user from a port, but I did not find a command to do that.
As a last resort I can simply shutdown the port, bring it up again ("shutdown" and "no shutdown" in the interface config), then all users are removed from the port and they all must reauthenticate. But it causes a network outage for a couple of seconds for all users on that port, on a busy access point it is quite disturbing, and it is not an elegant way to do this.
So my actual question is: is there a way to remove an authenticated user either automatically (Idle-Timeout and Session-Timeout) or manually from this switch?
I enclose the relevant part of the running config.
Thank you very much in advance.
Best regards,
Geza
interface range gi1-2
dot1x host-mode multi-sessions
exit
vlan database
vlan 2-4
exit
interface vlan 3
dot1x guest-vlan
exit
dot1x system-auth-control
dot1x reauthentication
exit
dot1x mac-authentication mac-only
exit
dot1x radius-attributes vlan
exit
dot1x guest-vlan enable
exit
interface gigabitethernet1
dot1x port-control auto
exit
interface gigabitethernet2
exit
radius-server host 192.168.33.195 key testing123 priority 1 usage dot1.x
aaa authentication dot1x default radius
Hi Geza ,
Thanks for the update .
I think we could take this in our regular community QA section .
Wireless - Mobility
Security and Network Management
This section is dedicated to Wired guest access  on WLC .
Will be answered  accordingly
Regards ,
Sharath K.P.
Hi Sharath,
Thank you for the reply.
I did a post in the "Small Business Switches" section (https://supportforums.cisco.com/thread/2128103), because it is not a problem with the wireless part (it was just easier for me to test it that way), but rather a problem of how the firmware handles radius reply attributes. But I am looking forward of any answers in any sections .
Best regards,
Geza
