Assign different SSID to radio on dual band AP
g.peart
Hi All,
I have a 2602i joined to a 5508 (7.5) and was wondering whether it was possible to assign different SSID to each radio.
E.G  SSID-A = 2.4GHz and SSID-B = 5GHz on a per AP basis.
There was a featured call WLAN override on earlier controllers, but can't seem to find the option on the 5508
As long as you create these two SSID only to advertise from this single AP, then yes you can do this. If this is the case you can define these two SSID, using WLAN ID greate than 16 (eg WLAN ID 21 fro SSID-A &  WLAN-ID 22 for SSID-B). Then create a AP group and add these WLAN with given radio policy restriction & your AP to this group.
But if these SSID needs to be advertise by other APs as well (without this radio policy restriction), then it cannot be done.
Rasika
*** Pls rate all useful responses ****
When you configuring WLAN, you can set a radio policy under WLAN general tab. So SSID-A you can set it t0 802.11g only & for SSID-B you can set it to 802.11a only.
This will be WLAN specific & affect all the APs.
Rasika
I wanted it for a single AP, is that possible
Rasika
g.peart
That's what I thought, thanks for confirming
Sent from Cisco Technical Support Android App
