Authenticate wireless users with Active Directory and NPS
John Woods
We currently have a wireless infrastructure consisting of 2702i access points and a 5508 controller. We have a guest (Internet only) SSID and also a private (corporate) SSID. We are currently using PSK for the corporate wireless but I would much rather have users authenticate through Active Directory. I have Googled this and see some people say it is possible using Server 2008 R2 and NPS.
Has anyone ever successfully deployed this solution? If so, I would greatly appreciate information on how to configure this. One key thing to note is that we do have non-domained devices that will still need to authenticate against user accounts in AD.
Thank you in advance,
John
George Stefanick
Hi John,
You will have some reading to do my friend. I will outline the key components and the process with some links.
802.1X -
You are looking to do 802.1X (EAP). Whereby you leverage a radius server NPS and authenticate users against a database, in this case AD.  If you never done this before. Know that you will need to configure the radius side and also the client side.
http://technet.microsoft.com/en-us/library/cc759077(v=ws.10).aspx
NPS -
Configuration
http://technet.microsoft.com/en-us/library/dd283091(v=ws.10).aspx
EAP -
You will have to select an EAP type. The most common and widely supported is EAP-PEAPv0. It supports MsChapV2. I might suggest leading with EAP-PEAPv0.
http://www.networkworld.com/article/2223672/access-control/which-eap-types-do-you-need-for-which-identity-projects.html
WLAN -
You will need to configure your WLAN as 802.1X.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70sol.html
CLEINT -
You will need to configure your clients with PEAP.
https://supportforums.cisco.com/document/68096/peap-authentication-configuration-example-windows-7
Hope this helps ..
George, thank you for the detailed reply. I will let you know how it goes.
Thank you,
John
Jeffrey Keown
