10-14-2018 08:56 PM - edited 07-05-2021 09:18 AM
Dear Sir/Madam,
I am facing technical issue with WLC. After some days time and date are automatically change in WLC. Because of that all access points are not able to communicate with WLC. So I appreciate if anyone help me to solve this issue.
Thanks & Regards,
Riyaz Patel
10-14-2018 09:24 PM
Hi Riyaz,
How u hve configured time in WLC. Is it using ntp or set the time manually. If ntp then the server is placed locally or using external server available over internet?
10-14-2018 09:41 PM
10-14-2018 09:51 PM
How can i solve this issue ?
10-14-2018 09:53 PM
Setup your NTP. Here is a link on how to do that:
