Popup Hotspot Using ISR 1000 with WiFi/LTE for Teleworkers and Micro Branchesr
Ask Me Anything – How to Enable Network Connectivity to Remote Workers
1191
Highlighted
aux port telnet login policy for IOS router
Hi all, I hope you can make me understand better how login policies work on IOS.
My 1721 router is configured for ssh access to the IOS, when I login into ssh I grant EXEC privileged access. That's ok.
I have connected the AUX serial port to another apparatus, and enabled it as a modem port. I use telnet to access it. I want to have a simple authentication (only a password, or username&password) to have access to the telnet and the aux port. But in any case I don't want this account to access the IOS through ssh.
Here are some extracts of the configuration:
enable secret 5 [mysecret]
aaa new-model
aaa session-id common
username [myuser] privilege 15 secret 5 [mysecret] <- this is used with ssh
line con 0
line aux 0
password 7 [mypass]  <- only this does not work
modem InOut
no exec
transport input all
stopbits 1
speed 2400
line vty 0 4
access-class 1 in
privilege level 15
transport input ssh
I read that there are several methods, using or not AAA, but trying both I cannot reach my goal.
If I add an user with privilege 0, he still has access to IOS enabled console, that's not good.
If I disable AAA functionality, the configuration would be like this:
no aaa new-model
line aux 0
password 7 01000716580A1C152E
login
modem InOut
no exec
transport input all
stopbits 1
speed 2400
line vty 0 4
access-class 1 in
privilege level 15
password 7 00171214075A111C00
login
transport input ssh
In this case, I can have the telnet login for the AUX port to work, as I want, but I am no more able to log into SSH again.
What is wrong? How can I achieve the two different login to work, according to your experience?
Thanks.
Alessandro
4 REPLIES 4
Highlighted
VIP Mentor
Hi Alessandro,
The AUX port is the auxiliary. Think of it as a secondary console port. The AUX ports don't get a lot of use except to access the router if locked out of the console port.
For VTY lines:
Router(config)# line vty 0 4
Router(config-line)# password 7 00171214075A111C00
Router(config-line)# login local
Router(config-line)# privilege level 15
Router(config-line)# transport input all -> (telnet or ssh)
what is the config for access-list 1 ???
Still not works...then can u please paste the config ....
Dont forget to rate helpful posts
Highlighted
Re: aux port telnet login policy for IOS router
I will try to explain better what is my problem.
I need to have two different logins, in addition to the classic enable in the console port:
- (A) one SSH login, for router configuration, that is privileged and can do any administrative task.
- (B) one TELNET login to the AUX port, that is a dummy user, and accesses to another apparatus connected to the AUX port. This user is must be prohibited from accessing the router's IOS.
I will now paste two configurations:
- with configuration (1) I can do "ssh user@router", put the password, and then enter into "router#" (enabled command line), BUT if I do "telnet router 2005" (2005 is the port mapped to the aux0) I'm asked for user&pass and the only account that works is the main account. If add "username dummy privilege 0 password dummypass" to the conf, this user will be able to enter telnet but also ssh enabled command line. So (A) works, (B) does not.
- with configuration (2) I cannot do "ssh user@router", as no password is accepted. But I can do "telnet router 2005" and give "dummy" username and "dummypass" password. So (A) does not work, (B) does.
Configuration (1)
version 12.4
service password-encryption
hostname router
boot-start-marker
boot system flash:c1700-k9o3sy7-mz.124-13a.bin
boot-end-marker
logging buffered 4096 debugging
aaa new-model
clock timezone CEST 2
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address [someaddress]
ip dhcp pool InternalLan
[omitted]
ip cef
ip domain lookup source-interface Dialer0
ip domain name [mydomain]
ip host [omitted]
ip inspect name [omitted]
crypto pki trustpoint equifax
enrollment terminal pem
revocation-check none
crypto pki certificate chain equifax
certificate ca [omitted]
  quit
username user privilege 15 secret 5 [mysecret]
ip ssh authentication-retries 2
ip ssh rsa keypair-name sshkeys
ip ssh version 2
interface ATM0
[omitted]
interface BRI0
[omitted]
interface FastEthernet0
description Interfaccia FastEthernet0/0 - Lan interna
ip access-group 100 in
ip nat inside
ip virtual-reassembly
speed auto
ntp multicast
interface Dialer0
description Interfaccia Dialer0 - ADSL
ip ddns update [omitted]
ip address negotiated
ip access-group 101 in
ip nat outside
encapsulation ppp
dialer pool 1
fair-queue 64 16 256
ppp pap sent-username [omitted]
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat translation [omitted]
[omitted - various nat tranlations]
ip dns server
ip dns primary [omitted]
ip access-list extended nat
permit ip 192.168.1.0 0.0.0.255 any
permit icmp 192.168.1.0 0.0.0.255 any
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 100 remark FastEthernet0 in
access-list 100 [omitted]
access-list 101 remark Dialer0 in - block all except dns, ntp, 220, 80, ssmtp, smtp, imaps
access-list 101 [omitted]
no cdp run
control-plane
line con 0
line aux 0
password 0 dummypass
modem InOut
no exec
transport input all
stopbits 1
speed 2400
line vty 0 4
access-class 1 in
privilege level 15
transport input ssh
ntp clock-period 17180048
ntp source Dialer0
ntp server [omitted]
end
Configuration (2)
version 12.4
hostname router
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
no ip source-route
[omitted]
ip cef
ip host [omitted]
  quit
ip ssh version 2
interface ATM0
[omitted]
interface BRI0
[omitted]
ip nat inside
speed auto
ntp multicast
interface Dialer0
ip nat outside
encapsulation ppp
dialer pool 1
no ip http server
ip dns server
no cdp run
control-plane
line con 0
line aux 0
login
modem InOut
no exec
transport input all
stopbits 1
speed 2400
line vty 0 4
access-class 1 in
privilege level 15
password 0 [mypass]
login
transport input ssh
ntp source Dialer0
end
Highlighted
I have partially solved by removing the following line from the "line vty" section
privilege level 15
Now the dummy user is not enabled by default, although can still access ssh.
A better solution would be restrict access to a user in the vty and one user in the aux, but I don't know how to do that.
Highlighted
VIP Mentor
HI Alessandro,
I am not sure but u can try to add this command under vty:
line vty 0 15
transport input all
transport output all
login local
access-class 1 in
Hope it helps.
Reagrds
Dont forget to rate helpful posts.
Content for Community-Ad
Cisco COVID-19 Survey
